Lg 50pk750 help!!!!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Lg 50pk750 help!!!!
    Why are you sad ? Its a positive thing that you diagnosed the fault successfully Order a board and let us know how it goes
    • LGinMD
      • Oct 2015
      • 26
      Hamie stated that the board is hard to come by
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ohh just read haha
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Or if you cant find one, we could go through troubleshooting the Mainboard but as your new to this it will be hard to do.
          • LGinMD
            • Oct 2015
            • 26
            Im not afraid to troubleshoot, with a little help
            • LGinMD
              • Oct 2015
              • 26
              Anyone care to guide me in the right direction?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #27
                Common issue on these boards is bga solder failing on the main processor which is under the heatsink, you could try reflowing it to see if it sorts the issue. Also do you know how to check voltage regulators ?
                • LGinMD
                  • Oct 2015
                  • 26
                  Ok, so pop off the board and check for bad points? I regards to the voltage regs no Im not 100% sure but am confident I can look it up... Or if youd like to link a video and or describe what to do thats fine as well.
                  • LGinMD
                    • Oct 2015
                    • 26
                    UPDATE!!!!
                    I just received the board, installed it and...... STILL NOTHING!!! :/
                    I unplugged the LVDS and shorted the two jumpers and the test patterns still work... WHAT COULD IT BE? I HATE TROUBLESHOOTING BLINDLY
                    HAMIE?
                    • Hamie
                      • Apr 2014
                      • 1383
                      You have bought a faulty mainboard.
                      97% you have a bought a faulty mainboard.
                      2% there is a problem with the control board
                      1% a problem with the lvds cable.
                      The board you have bought won't have been checked, send it back and get a refund.
                      • Hamie
                        • Apr 2014
                        • 1383
                        The test patterns bypass the main board.
                        If you get perfect test patterns then you've almost certainly bought a bad mainboard.
                        This is a common fault on this model, probably a lot of faulty mainboards floating about.
                        • LGinMD
                          • Oct 2015
                          • 26
                          This board was purchased as refurbished from a seller on ebay... I dont believe I can receive a refund. If I cannot Id prefer to troubleshoot this board to fix the problem.
                          Hamie, can you help me thru the steps I need to take to troubleshoot this board if I cannot get a refund?
                          • LGinMD
                            • Oct 2015
                            • 26
                            I have a question, could it be the AC Det? This is posted in the manual I downloaded
                            d Note: If the AC Det line is Missing, the TV will not turn on. (Relays will click, then no functions).
                            ^^^ This is exactly what its doing, it clicks then no functions...
                            • LGinMD
                              • Oct 2015
                              • 26
                              Bringing this back from the dead, can anyone help me troubleshoot the main board? I have a multimeter and can follow directions
                              I want to be 100% the Main board I purchased is bad before trying to source yet ANOTHER one!
                              Thanks!
                              • LGinMD
                                • Oct 2015
                                • 26
                                Hello, anyone?
                                Anyone?
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #36
                                  just to clarify in post 20 you asked which was the mainboard as you wasnt sure no one replied so you have found one yourself just trying to confirm you actually purchashed a main board and not a control board, if you did purchase a mainboard and it was faulty why not get a refund? as ebay gaurantee refunds or paypal on faulty goods and maybe even credit debit cards you shouldnt be out of pocket for faulty goods.
                                  • LGinMD
                                    • Oct 2015
                                    • 26
                                    Hello Vince,
                                    I did purchase a main board and after installing it nothing changed. The ebay seller I bought it from had a 0 return policy because I could not prove to him it was faulty, thats the reason for asking for help to troubleshoot it so I could prove to him it was faulty. He stated that it wasnt and Paypal/Ebay will not refund you your money...
                                    I need to know how to test (using a multimeter) to see if the main board is bad as well as the control board...
                                    • LGinMD
                                      • Oct 2015
                                      • 26
                                      Really, need help here
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #39
                                        Hi i have read various threads no one has seemed to of repaired one of these mainboards successfully hence the short supply of them i honestly dont know what else too suggest you check as your tests still point too a bad mainboard.
                                        • 2old2
                                          • Feb 2016
                                          • 7
                                          Thank You! Our TV went out 2 days ago same thing. I used Hamie's trick and got the test pattern. Could not find a replacement main board and could not see anything obvious on the old one sooo I put it in the oven (on wooden dowel rods) for 10 minutes at 390 degrees F. I let it cool before moving it and now my TV works! Thanks again!!
                                          • legg
                                            LG 42PC3 buffer output doesn't follow YSUS
                                            by legg
                                            LG42PC3D -UD originally with green lamp but no display or audio.
                                            Owner says was working, then went 'pop'.
                                            All 5V caps bulging. replaced.
                                            All PSU output voltages within spec but -Vy is low on YSUS.
                                            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                                            eventually shorts DG. Replaced all 3 - -Vy now OK.
                                            Y scan buffer test point does not follow YSUS output below -50V
                                            Note: This unit seems to expect YSUS output to park at -Vy in between
                                            drive signal pattern periods. A replacement drive signal board confirms this....
                                            11-18-2021, 11:49 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • Yanleb
                                            Schematic or datasheet for Plasma TV buffer chip
                                            by Yanleb
                                            I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                                            So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                                            Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                                            05-18-2022, 01:36 PM
                                          • PlasMatt
                                            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                            by PlasMatt
                                            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                            09-20-2025, 06:50 PM
