Samsung 50" LN52A580P6F Vertical lines
  • jakebouton
    • Oct 2015
    • 4
    • United States of America
    I have vertical white and black solid lines on right half of the screen. So far I have checked the ribbon connections to the t-conn board and switched them, same result with the vertical lines. I then replaced the t-conn board, still have the vertical lines. I checked the ribbon from t-conn to power supply, no changes. Now I don't know what to do? Can anyone help me out?
    Thanks,
    Jake
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Samsung 50" LN52A580P6F Vertical lines
    This is probably a tab bonding failure at the top of the screen. Pictures?
    • jakebouton
      • Oct 2015
      • 4
      Since posting I have read other posts about the tab bonding and will look into it tomorrow when I get to class. I can posts pictures, what specifically should I take a picture of?
      Thanks for your help...
      • freakaftr8
        • Oct 2012
        • 3743
        Take pictures of what the screen looks like what you're seeing
        • jakebouton
          • Oct 2015
          • 4
          It was the the tab bonding, I got it fixed.
          • Falki
            Colorful LCD Vertical Lines on Samsung ue55es8090
            by Falki
            Hello there, ive recently found an older 55inch Samsung SmartTV.
            A similar issue has been posted as well but also with no actual response ...
            08-12-2025, 04:19 AM
          • Stanley1843
            by Stanley1843
            06-29-2024, 11:54 AM
          • x_orange90_x
            Samsung UN46C8000XFXZA vertical bars/horizontal lines
            by x_orange90_x
            I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
            The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
            09-04-2023, 12:09 PM
          • polaro
            Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
            by polaro
            Greetings,
            I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
            08-27-2022, 08:46 AM
            09-07-2024, 05:50 AM
