Hitachi P50S601 plasma tv horizontal lines
  • tech2014
    • Aug 2014
    • 807
    This tv originally had a power issue. The screen would come on for a few seconds and there was a vertical bar on the right side of the screen. I found the upper buffer was shorted. I replaced the board. The tv now powers up, but now it has these lines on it. Could this be a bad YSUS?
    I disconnected one buffer at a time and the lines were still there, so its not a buffer board?
    Re: Hitachi P50S601 plasma tv horizontal lines
    I would check the buffer ribbon cables are seated right.
    • tech2014
      • Aug 2014
      • 807
      Hi Tom. Thats the first thing I tried. I reseated them all a few times and no change.
      • ozzy214
        • Nov 2013
        • 319
        • usa
        That looks like a buffer issue to me. Did you get a bad buffer? Look at the ic chips to see if they are meleted or have craters in them.
        • tech2014
          • Aug 2014
          • 807
          The buffer ICs look good on both, no craters. If the buffer board is the wrong version, would that cause the problem. It looks exactly the same as the original one.
          • Digglr
            • Mar 2014
            • 30
            I have the exact same issue with the same model. The SDR-U boards were bad, replaced with brand new ones. Now it powers up, but lines. I reseated/cleaned ribbons many times. No change. Is it possible its the Y-sus?
              This is not the Y-main, it is buffers or connections. The cables are very hard to get seated right, so remove the ones for the part of the screen that is dodgy and try again.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Originally posted by tom66
                The cables are very hard to get seated right.
                Just like the RAM on socket 775 motherboards..... LOL...
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • Digglr
                  • Mar 2014
                  • 30
                  Is there a trick to the cables? I'm definitely no expert, but have tried seating the cables about 30 different times.
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • kdaniel
                    Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
                    by kdaniel
                    As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
                    There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
                    After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
                    Left...
                    11-16-2022, 09:23 AM
                  • Ihandyrepair
                    Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                    by Ihandyrepair
                    Hi guys
                    I just started fixing 4k TV few months ago. so I am still learning a lot
                    I got this tv from friend complaint is ghosting or horizontal lines on image.
                    never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                    then it started to show the ghosting white image.
                    I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                    it has 3 thin small boards at the bottom of the...
                    12-05-2022, 04:18 PM
                  • ggil44
                    Sony XBR-65X750D Horizontal lines bottom of screen
                    by ggil44
                    Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                    05-30-2023, 07:51 PM
                  • rstrube
                    ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
                    by rstrube
                    Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
                    Hi Everyone,
                    I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
                    Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
                    11-23-2025, 01:37 PM
