Vizio GV42L HDTV blows fuses won't come on
  • gmussman
    • Oct 2015
    • 7
    I've never repaired a TV before and I'm pretty new to trying to fix electronics, though I can solder into a PCB and I can use a multimeter.
    I have a Vizio GV42L HDTV -- its an LCD flat screen. Its totally dead. I took it apart and the fuse was blown, so I replaced it. I didn't see anything else obviously wrong with the power board. When I plugged it bag in, I heard a variety of snapping-popping sounds without any signs of life from the TV. Taking it apart again, the fuse is blown but again no other obvious pathology on the power board.
    I attached some pics of the power board. What should I do next to figure out what is going wrong?
    Thanks,
    Grant
    Re: Vizio GV42L HDTV blows fuses won't come on
    You need to start testing the power devices such as bridge rectifier, POWER MOSFETs, ETC. You have shorted out circuit some where on the board.
    I do not know how much of the component level troubleshooting you want to go, the new board is about $40.
    http://www.shopjimmy.com/vizio-0500-...wer-supply.htm
    • gmussman
      • Oct 2015
      • 7
      Oh, that's a much better price than I was finding!
      If I did want to test said components, is there a thread or guide you could recommend that would explain what they look like and how to test them?
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
      • acedogblast
        Power supply for main amp blows fuses after replacing filter caps.
        by acedogblast
        Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
        I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
        I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
        02-27-2023, 05:11 PM
      • Sraros
        17PW15-8 blows fuses after lightning
        by Sraros
        I picked this PSU 17PW15-8 from a friend's TV with a burnt fuse, after some days of rain and lightning strikes. The TV was on standby when it happened.
        With new fuses it burns them as well. I checked bridge rectifier, all the TO220 components, diodes and basic caps, replaced IC806 SMPS, and FETS driving the big transformer. I also isolated the secondary circuit by cutting the rails of the FETs to the primary coils. I don't know even know if that makes sense, but I did in hopes to isolate the problem.
        Any ideas what to look for?...
        12-04-2023, 01:26 AM
      • SS454
        vizio e650i-a2 backlight flashes then turns off
        by SS454
        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
        panel: au optronics T650HVN05.4
        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
        https://www.shopjimmy.com/vizio-56-0...-power-supply/
        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
        08-20-2020, 03:57 PM
