LG 60PZ950S weird problem
  • Iersuo
    • Oct 2015
    • 31
    • Ulu
    Hello! My Plasma LG acts weirdly. When I turn it on the picture is fully black, but the black starts to receed from the center of the screen to the edges slowly. After about 30min the picture is fully visible but it is still dim and colors are really pale. Color doesnt return to normal even after a longer period of time. Where can the problem be, anyone has any suggestions?
    загрузить картинку на сайт
  • tw2005
    • Oct 2011
    • 6458
    Re: LG 60PZ950S weird problem
    I'll say failed Zsus
    • Hamie
      • Apr 2014
      • 1383
      Originally posted by tw2005
      i'll say failed zsus
      +1
      • Iersuo
        • Oct 2015
        • 31
        • Ulu
        Originally posted by Hamie
        +1
        Why exactly z-sus you suspect? Any further reading on this? Also read somewhere both z-sus and y-sus are usually replaced together?
        • Hamie
          • Apr 2014
          • 1383
          You don't need to replace the z and y together.
          On Some Tvs if one fails it can take out the other, but that would depend on how the boards are linked up.
          Your boards haven't shorted so aren't in danger of blowing other board, you probably have a faulty surfacemount IC.
          • tw2005
            • Oct 2011
            • 6458
            dim picture and black splotches are usually classic symptoms of bad zsus,xmain,SS board depending on the brand on what they call them. As for mandatory replacement of both, maybe with the older IPM based boards but i would think doing just the zsus would be ok or do both if you're worried.
            • Iersuo
              • Oct 2015
              • 31
              • Ulu
              Ok, got it, I will look under the hood and take pictures of that. Is the failure of Z-sus usually visible or is it internal? Better to change the whole board I guess, not to try and tinker with fixing? Also the TV makes an irritating buzzing noise all the time and it changes in frequency when the picture changes, too loud to be a "feature" of the tv I think, can that also relate?
              Wanted to thank alot for trying to help.
              • Iersuo
                • Oct 2015
                • 31
                • Ulu
                Found 2 discussions of the same issue, looks like z sus indeed. Will examine it further and comment later. Seems like in the second link, new z-sus did not help or maybe got instantly broken due to another flawed component? Any ideas?
                https://www.badcaps.net/forum/showth...ght=Lg+60pz950
                https://www.badcaps.net/forum/showth...974#post539974
                • Iersuo
                  • Oct 2015
                  • 31
                  • Ulu
                  Want to update on the progress so far... Took off the Z-sus and yes indeed soldering of the coils was damaged like in the picture. The board itself looks darker around the coils probably because of the heat. Went to a repair shop and asked those contacts to be re-soldered, but that did not help a single bit.
                  Now I searched for a replacement board but cant find one, out of stock everywhere. Product numbers are: EBR73561701 and EAX64232101
                  However managed to find two repair kits:
                  http://www.ebay.com/itm/LG-Z-Sus-Rep...-/131530589936
                  and an "improved kit"
                  http://www.ebay.com/itm/New-Improved...-/191568197879
                  Do you think the repair kit should be enough to get the board repaired or not? Which kit is better, or should I just let the repairshop get all the needed equipment themselves? Also there is an adjustment knob on the board what is that for? Maybe I could troubleshoot the board with a multimeter? I can see a lot of data on the board of what is supposed to be expected reading from a multimeter, anyone has a link to a guide on how to do this?
                  • tw2005
                    • Oct 2011
                    • 6458
                    had a suggestion then saw you've refolwed the joints-deleted
                    • Hamie
                      • Apr 2014
                      • 1383
                      Ic215 and ic216 drive ICs are included in the second kit.
                      If I were to replace anything it would be these two.
                      The rest of the kit is for for a completely blown z-sus with an open fuse.
                      Why not buy ic215 and ic216 first.
                      • Iersuo
                        • Oct 2015
                        • 31
                        • Ulu
                        Got the TV fixed! Ordered a repair kit for Z-sus board from Shopjimmy.com
                        LG EBR73561701 (EAX64232101) ZSUS Board Component Repair Kit (cost 25 euros)
                        Got everything that was in the kit replaced by a professional (cost 60 euros)
                        Now working flawlessly Thank you Hamie and TW2005 !!!
                        • index
                          • Jun 2016
                          I have exactly the same problem. Can someone please tell me the partnumber/ manufactor of IC215 /IC216. Thanks.
                          • pmatrisotto
                            • Nov 2011
                            I have a 50PK950 Plasma set that i need to repair. I'm not sure which board to start with? I'm attaching a video of what the TV does. can anyone give suggestions?
                            https://youtu.be/y1askNdDWbQ
                            • Hamie
                              • Apr 2014
                              • 1383
                              Start your own thread, looks like a mainboard fault.
                              Need to run test patterns to be sure.
                              • pmatrisotto
                                • Nov 2011
                                Hamie, I tried to start a new thread and it says I don't have permissions.
                                How do I run the test patterns?
                                • chaos-theory
                                  Nitro rx580 very weird problem, VCORE and EN
                                  by chaos-theory
                                  Hello!
                                  I have this very weird problem, I got this rx580 nitro saphire and the fans don't even spin but the saphire logo is lit.
                                  All voltage rails are present except for VCORE at the coils, then I started checking NCP81022 and it has voltage but vdd pwrgd is missing, enable EN is missing it shows 2.5ohm, everything seems fine, i tried checking the back of the card, to see where the enable pin goes, i dont have a schematic so i started touching randomly until i measured a resistor on the back and the fans started spinning, now I was amazed like what is wrong here? So I thought it's a...
                                  08-17-2024, 04:56 PM
                                • c.daniel
                                  Lenovo V310-15IKB weird bios problem...
                                  by c.daniel
                                  Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
                                  sn LR09493E
                                  MB DAOLV6MB6F0 REV. F
                                  The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
                                  Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
                                  Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
                                  Today, 05:39 AM
                                • sorrowfulfloyd
                                  Samsung UE32J5373AS Weird LED Problem
                                  by sorrowfulfloyd
                                  Hi all, first time seeing a LED problem this weird so I wanted to discuss with y'all before handing back this TV to my costumer.
                                  This TV came to my shop with no picture but sound present. So I thought ok this must be a LED problem and I shine a light with my phone's torch amd and yup I see the image. So I disassemble it and before changing the LEDs I check the motherboard voltages (this unit works with an external 16V DC brick) and I see 54 volts at the input pin of LED strip, considering this TV has 2 strips of 7 LEDs which at 3~ volts it must be equal to like 42 volts. I remove...
                                  12-23-2022, 07:00 AM
                                • theone111
                                  by theone111
                                  3. Problem: TV shuts down
                                  07-22-2024, 10:36 AM
                                • brockauly
                                  Macbook M1 A2337 EMC 3598 weird battery charging problem
                                  by brockauly
                                  Hi guys,
                                  If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
                                  Then if I unplug the charger and plug it back, it won't charge anymore.
                                  In the first case, main voltage is regulated at ~12.5V and charges the battery.
                                  After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
                                  After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
                                  I found C520A (2.2ยต after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
                                  02-05-2025, 10:51 AM
