Schematic for Samsung BN94-04357A Main board anyone?
  • jcamerox
    • May 2015
    • 34
    The board is from a Samsung UN55D6500VFXZC led tv. The power supply seems okay because the backlights come on with the main cable disconnected and then with the main connected, the power cycles on and off, relay clicking every 5 seconds. No audio or video. I was able to find a service manual but all it has is block diagrams and cable connectors. Need the electrical schematic for the main board. Thanks.
  • Hamie
    • Apr 2014
    • 1383
    Re: Schematic for Samsung BN94-04357A Main board anyone?
    As far as I'm aware Samsung don't release schematics for main boards.
      Not for ones this new, certainly. They did for some older models.
      • jcamerox
        • May 2015
        • 34
        Thanks for the replies Hamie and tom66. I will stop trying to find one and concentrate on getting a replacement board. I was trying to find out why there was no power going to one of the on board voltage regulators, one of the few components I might try to replace on a main board.
          Is the power supply outputting 5V & 13V?
          Check PS ON signal - if not LOW or changing when turned on, can be main board fault.
          • Asraf Atb
            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
            by Asraf Atb
            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
            01-27-2025, 05:02 PM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • Lee M.
            Samsung UN75RU8000FXZA bad main board?
            by Lee M.
            When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
            11-08-2023, 07:46 PM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • JDC
            by JDC
            ONN 100012588
            Long answer:
            07-15-2022, 07:39 AM
