Logik L39FE12 39” Led backlit LCD TV
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Fault:-
    Noise originally coming from the bottom of the set after which set failed to switch on. No standby light.
    Repair:-
    Remove PSU from set disconnecting all cables leaving only ac power cord connected.
    Mains ON/OFF switch found to be open circuit so shorted out for testing purposes.
    AC voltage now present at bridge rectifier which now provides DC to UI via T2 ; but no 5Vsb.
    Replace U1. 5vsb now up and running.
    Short 5vsb to Pon and all supply voltages present. 5V, 12v, 24V
    Re-Install power supply back into set and power up.
    Front panel Led blinks very briefly as PSU voltages rise and fall every second. Pon, 5vsb, 5v, 12v & 24v all toggling high and low.
    Removing the PSU once again and connecting Pon to 5vsb, I then loaded the +5v supply to draw 2 amps without any problems.
    Has anyone further ideas or maybe access to the main AV board schematic. (MSDV3206-ZC01-01(B), 303C3206072)
  • CapLeaker
    Leaking Member
    • 8327
    Re: Logik L39FE12 39” Led backlit LCD TV
    what is underneath that metal shield on the bottom of the main board?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Common issue is the flash memory chip causing the psu to restart over and over. Try removing Ps on and turn the Psu on then plug into mainboard and see if it turns on.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Hello CapLeaker,
        Its the Tcon board according to images on the web.
        Hello ReeceyBurger123,
        Thanks for that. I'll let you know the result.
        Regards
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          The results of your suggestion have been positive and listed below:-
          Removed CON4 as suggested.
          Plug in TV and switch on.
          Plug in CON4 -Blue light comes on and is steady.
          Set works.
          The set only works at the moment by plugging in CON4 after the set is switched on. If CON4 is already connected before being switched on, then the power supply cycles.
          If you could offer any further advice I would appreciate it.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Prior to ReeceyBurger123 suggestion, I had removed the PON connection and powered up then reconnected PON to the 5vsb. The supply voltages would come up but the 12V supply would only reach 10.8V and not 12V and the set would still not work.
            Taking this into account and my previous reply, would this point to still having a PSU problem?
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              I'm completely puzzled as to why ReeceyBurger123's suggestion works i.e. powering up the set first with the DC connector from the PSU to the main board removed, swithcing on the set and then plugging the connector into the main board resulting in the set up and running.
              But when the DC connector is in place and you power up the power led just flashes.
              Could anyone offer me any further suggestions to help me move forward. Is this a power supply problem?
              Regards
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                I said that to see if the mainboard was not bring the Pson low with means it wont turn on, as when its connected seems like the mainboard is shot.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Hi ReeceyBurger123
                  Sorry but I'm a little confused and hope you can bare with me.
                  Currently Pon is back in the connector and when switching on with CON4 disconnected and then reconnecting the set is working. So Pon does not appear to stop the set coming up.
                  Do you think it's still a mainboard fault?
                  Thanks for your assistance.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    An update.
                    Monitoring Pon the voltage is pulsing in line with all the other supply voltages. If I short Pin 9&10 (9= Pon, 10 = +5V) then the set goes into standby mode and can be switched on.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Thats what I meant, the flash Ic must have failed then.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        So looks like another one of these Umcs with failed flash Ic's. When it works does it give good image and sound ?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          The picture is not too bad considering the price of the set when new and there is reasonable adjustment of colour, brightness, contrast, backlight.
                          The sound is what you would expect from small speakers but you can put it through your surround sound system if you wanted to.
                          You say "failed flash IC". What is the link between the Flash IC and powering up and can the IC be reprogrammed when the set is up and running via the USB?
                          • CapLeaker
                            Leaking Member
                            • 8327
                            needs to be replaced and reprogrammed.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              Isolating the PSU from the TV I can apply 5vsb from a dc power supply while monitoring Pon.
                              When 5vsb is connected, Pon goes to 5V. Current drawn from power supply is 14mA.
                              In conclusion I now believe that I must still have a problem with the PSU so going to delve a bit deeper into it.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                You should replace the Ic then you will need to reprogram it pain in the ass to do though
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Hello CapLeaker,
                                  How would one go about reprogramming the Flash IC, where could you locate the firmware. Please could you tell me how you came to that conclusion. I'm still learning and have just returned to TV servicing after many many years and firmware in TV's is all new to me .
                                  Thanks in anticipation.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    The flash Ic is hidden under the main heatsink on this board pain to access as you have to desolder the whole heatsink.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      Thanks ReeceyBurger123,
                                      Hopefully that will not be too difficult. However if I do remove it do you know how one goes about to reprogram it, where to obtain the firmware and how does this link in with the PSU.
                                      Your advice is greatly appreciated.
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        No worries mate glad to help, what is the full model of the mainboard buddy ?
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • shamsudeen
                                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                          by shamsudeen
                                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                          07-19-2025, 07:14 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
