I have this Panasonic sc board and they make a repair kit for this but I wanna know how to check these transistors and diodes?
how to check these surface mount transistors and diodes?
Tags: None
Re: how to check these surface mount transistors and diodes?
Like any other transistor, just check across pairs of pins for shorts.
The middle pin and tab are electrically connected internally, so you don't have to test that.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Yes, and if one transistor in a parallel "set" is bad, ALWAYS replace other transistors in that same set, as well as all transistors in series.
Failure to do this can lead to an explosive first power on...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
check the IGBTs first in cct. then desolder and lift the 2 legs reconfirm whats shorted. You'll probably find with the shorted IGBTs isolated the diodes often will show as good.
check the gate resistors too once the bad IGBTs are removed.Comment
I use 400C temperature with a 65W soldering iron. They come off easily. The pads are very large and hard to damage.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
No dramas here either, likewise I use a quality broad tip to get that heat Transfer happening on the tabs, in fact I tin the whole tab.Comment
"how to check these surface mount transistors and diodes?" Same way as you test the Through hole devices. If it does not read right then you have to remove it and test it off the board.
Surface mounted device still functions the same way as the through hole device.Never stop learning
So just put in diode mode should read between 400 and 700 one way and open the opposite way?Comment
Did you actually read any of the posts above?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
MOSFET is another story.
May be you should get a hold of some good NPN, PNP transistors and some N-CH, P-CH MOSFETS, then look up the pin out and take the readings to see what you get on the good device.Last edited by budm; 09-24-2015, 07:02 PM.Never stop learning
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-06-2024, 08:10 PM
- Loading...
