Samung TV Model LN46C630K1Fxza Vertical colored lines
  • bfortune206
    Burkes
    • Sep 2015
    • 23
    Tv has intermittent vertical colored lines. (All the way across the screen) Can slap back of TV and some times it will play for several hours and do it again. Any help will be appreciated.
  • Hamie
    • Apr 2014
    • 1383
    Re: Samung TV Model LN46C630K1Fxza Vertical colored lines
    Pictures?
    your description makes no sense.
    • bfortune206
      Burkes
      • Sep 2015
      • 23
      Will do. The owner is not at home today. FYI I have heard there night be a loose ground on the main board.
      • zlw1
        • Sep 2015
        I would try the LVDS Cable first.
        If it covers the menu as well, evaluate the main or t-con.
        • mmartell
          • Oct 2013
          • 3189
          You say "vertical" then you say "across" which can only be if the lines cover the entire screen ???
          As Hamie says, pics...
          • Stanley1843
            Screen Display Vertical Multicolor Lines
            by Stanley1843
            Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
            06-29-2024, 11:54 AM
          • pni
            LG 49uf695v vertical coloured lines
            by pni
            Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
            11-14-2025, 03:15 AM
          • Falki
            Colorful LCD Vertical Lines on Samsung ue55es8090
            by Falki
            Hello there, ive recently found an older 55inch Samsung SmartTV.
            Sadly it has vertical lines at the left and one line in the middle-right.
            I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
            I have factory resetted the TV as well but also with no luck.
            I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
            A similar issue has been posted as well but also with no actual response ...
            08-12-2025, 04:19 AM
          • visionbluedemon
            Help. Sony kd-65x85dj vertical lines
            by visionbluedemon
            First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
            Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
            tried blocking LC lines too, but same results
            is it lcd panel issue or tcon board issue?...
            07-25-2025, 04:56 AM
          • gpo23
            Sony KDL-40V3000 - Vertical lines
            by gpo23
            i order a t-con because i had bad colors on my SONY KDL-40V3000 :
            With the new t-con the color are good but there are vertical lines on all the screen :
            I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
            Is there a way to fix the vertical lines on the new t-con ?
            Thank you for your help
            gpo23...
            10-04-2023, 09:11 AM
