Sylvania screen dark spots
  • dbier63
    • Aug 2015
    • 157
    • usa
    I recently acquired a sylvania 37" Model LC370SL8. It has a dark shadow on the lower right side of screen. Shadow is faint you can see through it. I have also noticed this issue on another smaller sylvania I had in the past. Never tried to fix that one though. Can anyone help with this issue?
  • Rozp
    70LE660U dark cloud or black screen with sound.
    by Rozp
    Hello Everyone,
    This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
    I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
    08-29-2023, 05:25 PM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • scubacamper
    Sharp Aquos LC-70C6400U Half Screen Dark
    by scubacamper
    I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
    Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
    when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
    05-03-2025, 12:19 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
