Sharp TV LC-42LB261U- Doozey! No LED from power after the PSB has been replaced
  • Fellow
    • Sep 2015
    Wouldn't turn on when plugged in. No LED indicator either. Thought for sure this would be a PSB problem.
    Replaced the PSB the first time and thought it was just a bad unit. Returned. Ordered new PSB. Plugged this one in and still the power button does not a thing when touched.
    Puzzling... And I'm a TV repair noob, so I request guidance from the elder gods. I have a volt meter and a soldering kit.
    Could this somehow be a problem with the actual cord connecting the PSB to the button board?
    Could this be a main board problem somehow?
    Waddup wit dat?
    Edit:
    Oh, I also checked the DC voltage out from the PSB.
    The schematic on the board said:
    15. 5v 16. 5v
    12v 12v
    12v 12v
    12v_A 12v_A
    GND GND
    GND GND
    And sticking the pins in each one of them I only got a few that read 15v. Is that normal?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Sharp TV LC-42LB261U- Doozey! No LED from power after the PSB has been replaced
    Prolly a Mainboard fault.
    TELEFIX
    • Maklaud
      • Sep 2015
      • 56
      • Russia
      Hello.
      Can you use service manual?
      • advant
        by advant
        02-03-2020, 12:25 AM
      • MicroSMD Lab
        MSI MS-16W1 no power, EC replaced by other.
        by MicroSMD Lab
        Hi, I'm working on a MSI laptop, Motherboard number MS-16W11, GF-65 Thin 10SDR-459US. Went to another shop because the screen was flickering, but it was working well on an external monitor. The LCD was ordered and the laptop was returned to the customer and it no longer worked. It was then sent to another tech (by the shop who ordered the LCD) and the EC (ENE KB9028Q) was replaced with a donor from another MSI board with different board number and no programming was done. It looks like work was done on PU6 (TPS51225) as well as one of the GPU mosfets was burnt (I removed all three GPU mosfets)....
        03-27-2025, 07:35 AM
      • Superbee_dad
        Sharp 80” long short flash backlight error - Help
        by Superbee_dad
        Hello Sharp TV experts
        Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
        > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
        > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
        01-24-2025, 11:51 PM
      • blablaro
        Philips PSU (715G7350-P01-000-002S) No stand by light (0V)
        by blablaro
        This is the source from a Philips TV 43PUH6101 that suddenly stopped.
        I know it's the source since I have ~ 0 volts on outputs 12VA/16VA, 12V/16V, +3.5/+5V
        For the latest weeks I've been trying to figure out the problem with this. I've ordered all kind of mosfets, a capacity meter and other things to try to figure out the issue with this PSU. My wife thinks I'm crazi but I want to repair it
        Initially, when I started the testing with the multimeter on diode mode (220 V on):
        - discovered that was Q9101 shorted (or I shorted it)
        09-24-2025, 10:21 AM
      • betmen
        TV Sharp LC-49CFE6242E - not working
        by betmen
        I get one old TV, Sharp LC-49CFE6242E which is not working.
        When turning on the TV, the inscription SHARP is displayed on the screen and after a few seconds the TV turns off.
        So far I haven't found what voltages should be at the output of the power supply and I haven't made any measurements.
        If anyone has any ideas, please let me know.​
        Starts
        10-19-2024
        Ends
        11-19-2024
        10-20-2024, 08:44 AM
