Tc-p55ut50 8 blinks
  • ricosavy
    • Jul 2012
    • 457
    • united states
    Tc-p55ut50 8 blinks
    I looked at my ss board and it had a short transistor dg302.So I ordered the kit from shop jimmy.i recieved the kit and installed it and it shorted out again.i noticed on the kit for the tc-p50ut50 one the was a ic but not on the tc-p55ut50.is there another component that shorts out.
  • ricosavy
    • Jul 2012
    • 457
    • united states
    Re: Tc-p55ut50 8 blinks
    The ic that is included in the kit for tc-p50ut50 is ic152 but i think ic153 does the same thing i wonder if that is causing my short.the tc-p55ut50 does not use ic152 but has ic153 and tc-p50ut50 does not have ic153 and does have the ic152.
    • ricosavy
      • Jul 2012
      • 457
      • united states
      Looks like part number is C0ZBZ0001936 could this be cuasing my short
      • ricosavy
        • Jul 2012
        • 457
        • united states
        My part dg302 shorted again could the ic that powers it be shorted
        • ricosavy
          • Jul 2012
          • 457
          • united states
          Ic153
            Yes, the bad IC can damage the new IGBT.
            • ricosavy
              • Jul 2012
              • 457
              • united states
              How can i tell if it is bad
                I would always replace it if there is any doubt.
                You can check the resistance from the output to Vcc or ground.
                Or use an oscilloscope to check the gate with the IGBT missing - it should swing between 0 and 15V, and not be stuck at either end.
                • ricosavy
                  • Jul 2012
                  • 457
                  • united states
                  Pin 7 out to ground i have 98.71 k ohms
                  • ricosavy
                    • Jul 2012
                    • 457
                    • united states
                    Numbers on chip are 4840 n46 jrc
                      You need to check to Vcc as well.
                      • ricosavy
                        • Jul 2012
                        • 457
                        • united states
                        SI4840DY Is this the same chip
                        • ricosavy
                          • Jul 2012
                          • 457
                          • united states
                          Vdd is 1.1 million ohms
                          • ricosavy
                            • Jul 2012
                            • 457
                            • united states
                            BD8694 i noticed some panasonic boards have this chip is it the same
                            • tw2005
                              • Oct 2011
                              • 6458
                              No mate, a SO-8 40V N-channel FET is not the same as a FET driver IC.
                              Here's a tip. JRC = Japanese Radio Company, 4840 is the IC number
                              Google JRC 4840
                              And this should be it.
                              good luck
                              • tw2005
                                • Oct 2011
                                • 6458
                                May do the same job but I believe that's a ROHM product. Never found a datasheet for that one
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Interesting when you google C0ZBZ0001936 it gets hits for BD8694 so maybe there was a change in supplier which may mean you could use BD8694 as well?
                                  • ricosavy
                                    • Jul 2012
                                    • 457
                                    • united states
                                    Makes sound like it can be used but i am not sure waiting for dg302 to come i order i will try find orginal one if not i will try bd8694.i am thinking this ic driver is probably my problem.What is strange is shop jimmy includes the ic driver for 50" tv and not the 55 one.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      yeah, well you know kits are not always the sure fix. I've never touched one of these so I can't help much either but replacing the driver is probably good practice. It's really hard to know what gets taken out. I've done 2010 Sc boards and doing the driver is pretty much essential. yet I've done a couple of 2011 SC boards and gotten away with just the IGBTs.
                                      Luck of the draw.
                                      • ricosavy
                                        • Jul 2012
                                        • 457
                                        • united states
                                        Here is what i have found out bd8694 is actually in the kit used for the tc-p50ut50 it is the bigger size ic chip.the tc-p55ut50 uses the smaller one.i will have to look at the diagram for the tc-p50ut50 to see if they are wired the same.and the only difference would be size.ic152 is the bd8694 that is used on the model tc-p50ut50 and it does not use and it does not use ic153.the board numbers are the same just the chips are different in size.and they both have the spots where to mount the chips
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • Nairolf
                                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                          by Nairolf
                                          I have a Samsung DM32D display.
                                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                          Here’s what I have tried so far:
                                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                          08-24-2025, 03:47 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • Taurus12
                                          Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                          by Taurus12
                                          Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                          I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                          i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                          Any recommendation on what I have to do next? Thanks in advance
                                          06-10-2025, 05:05 PM
                                        • jchon
                                          Sony A1e 5-blinks help
                                          by jchon
                                          Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                          I found the service manual, which was critical to know where to probe.
                                          https://www.manualslib.com/manual/20...1e-Series.html
                                          With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                          Unfortunately the 5-blinks...
                                          06-28-2023, 11:52 AM
