42PC3D No Prime
  • mmartell
    • Oct 2013
    • 3189
    42PC3D No Prime
    I swore off these sets but here we are...
    Set wouldn't turn on until I disconnected the zsus. Powers on and stays on, can hear the static from the speakers on what must be Antenna input but there is no screen prime at all.
    I have VS, VA, Vsc but no -Vy. Have not removed the ysus to check components yet. Could shorted buffers pull down just -Vy ?
    Also the zsus has no blown fuses so why would it need to have the power harness disconnected for the tv to start ?
    And is it safe to run the panel with the x buffers disconnected ?
  • mmartell
    • Oct 2013
    • 3189
    Re: 42PC3D No Prime
    At some point the zsus fulfilled its destiny as vs is now shorted to ground on it. I'm going to pull the ysus to see if I can find why -Vy is missing. Is -Vy generated straight from Vs on the little sub board ?
    I also took some measurements from the dc-dc converter and they don't look right. There are three what I thought were voltage regulators there but the measurements are off unless I'm doing it wrong. Are they not measured at pin 3 with respect to ground ?
    • mmartell
      • Oct 2013
      • 3189
      Re: 42PC3D No Prime
      Should there be a blinking led on this control board ? I have three temp leds but there is another one at D11 (in a different board location) which never lights.
      Also -Vy is missing with buffers both connected and disconnected. If I remove the ribbon going to the control board it comes back rock solid at -200v.
      Does this sound like a control board issue ?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Re: 42PC3D No Prime
        Yes Led should blink common issue on these is the Ipm under Zmain failing.
        • mmartell
          • Oct 2013
          • 3189
          Re: 42PC3D No Prime
          This happens with zsus removed. Thanks for the heads up on the blinking light, will order a control board.
          • mmartell
            • Oct 2013
            • 3189
            Re: 42PC3D No Prime
            This one ended badly. The folding table it was on had a leg give out resulting in the screen cracking itself on the concrete floor. Off to plasma heaven lol.
            • arabex21
              Asus Prime B450M-A starts only when 12v 8pin cpu plug disconnected
              by arabex21
              Hello everyone. I have been reading this forum for a long time - I really appreciate the amount of very interesting materials and information in the field of electronics.
              I have a problem with this configuration:
              ASUS PRIME B450M-A
              RYZEN 1300X (I replaced it with ATHLON 200GE - the same behavior, the processors are functional, tested on another board)
              When the entire set is installed (CPU, RAM, ATX connector and 12V 8 pin CPU plug), the board starts up for a while (about 1-2 seconds), the CPU fan starts and the board turns off immediately. When I disconnect...
              09-19-2024, 03:05 AM
            • ASB
              Asus Prime B450-Plus Bios Modification (USB Overcurrent)
              by ASB
              I have an Asus Prime B450-Plus motherboard with USB overcurrent shutdown problem. All the ports, voltages and resistors are ok. Can someone please help by editing bios to disable this feature? Another member (прямо) has successfully done this and shared the bios in forum but those are for other Asus models....
              11-12-2025, 06:17 AM
            • Geomih
              Asus Prime Asus PRIME X670-P r1.01X (60MB1BU0-MB0A06) boardview
              by Geomih
              Couldn't find this particular board on badcaps so here it is for safe keeping...
              08-16-2025, 01:52 PM
            • gatto
              LG 50PC56 keep burn Buffers Boards
              by gatto
              Hi, I’m new to the forum and this is my first post, so thank you in advance to having me, I have the fallowing problem, could someone please help
              I have this LG 50PC56 which not display image on screen
              I have already change Y-SUS and buffers 2 times! But this TV keep burning my buffers boards!
              When I do install the new Buffers board I been able to see only the top half part of the screen for about 10 min, and then it blow up again! The IC get very hot and I saw some smoke come out from it, so now I have another set of buffers burn out
              My question it is: I disconnect...
              05-04-2022, 01:35 AM
            • taurtnt
              ASUS Prime Z490-P boardview
              by taurtnt
              need ASUS Prime Z490-P boardview diagram
              Hi, I have an ASUS Prime Z490-P motherboard, it doesn't start and I need the boardview diagram, if anyone can help me
              01-24-2025, 10:26 AM
