Samsung pn51d550c1fxza bad picture
  • krygods
    • 257
    I picked this up for $20.
    Picture is really messed up on the left hand side of the panel.
    I've tried unplugging various ribbon cables from the TCON and seeing what happens.
    All I get it either one side is white with vertical black and white lines of the opposite side or vertical multicolored lines across the whole panel.
    Any thoughts? Bad panel, bad TCON?
  • krygods
    • 257
    Re: Samsung pn51d550c1fxza bad picture
    eH, I put the wrong model number in the thread title, this TV is a Samsung LN52A850S1F
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      I would say bad T-CON???
      • CapLeaker
        Leaking Member
        • 8325
        Is the screen on the left sluggish to respond? Flex the screen or give it a few good squeezes on the left side. I think tab bonds.
        • Maklaud
          • Sep 2015
          • 56
          • Russia
          What model is your t-con?
          What model is your panel?
          • krygods
            • 257
            yea seems sluggish on the left side. part of the right side is ghosting onto the left side.
            I've had the TV running for a few hours and the picture cleared up the right side looks great but the left side still sluggish.
            flexing the left side sometimes causes vertical and or horizontal colored lines.
            • CapLeaker
              Leaking Member
              • 8325
              tab bonds...
                If only one side is affected by the distortion consider some "tab surgery" to give the TV more life. (NOTE: May kill TV completely, may only work for a few hours, not reversible if you screw it up or it doesn't work, BUT it does fix some sets which have gate tabs on both left and right of the panel.) https://www.badcaps.net/forum/showth...t=48477&page=7
                • krygods
                  • 257
                  probably just going to sell the parts, I have plenty of working TVs and I don't feel right selling one to someone that is highly possible that it might fail soon after if I were to do some type of repair / surgery to the tabs.
                  I have been following that thread though and it's quite interesting and something I would definitely try myself if I had a really nice TV that I would like to use myself until it failed.
                    Yea, that's exactly my feeling - I couldn't sell one of those that I modded myself. I'd feel bad. I could only keep one for myself. And I've no space for a 50"+ LCD...
                      09-07-2024, 05:50 AM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • shelby5041
                      Samsung LCD TV no picture backlight on no 12v at tcon
                      by shelby5041
                      hi
                      i have a samsung lcd tv
                      it powers on with sound and backlight but no picture
                      all voltages from PS are good 12v 3.3v and 5v
                      whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                      i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                      no 12v at the tcon fuse
                      i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                      the odds of having 2...
                      10-08-2021, 08:21 AM
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
                    • brithepi2k
                      Samsung UE75TU7020k No picture, Standby blinks 2 times
                      by brithepi2k
                      My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                      04-23-2025, 10:05 AM
