LG 32lc3r / Sound ok Back light ok / No Picture
  • Xcat2008
    • Sep 2015
    • 25
    • Portugal
    Hello guys.
    So i have a Problem with my TV LCD LG 32lc3r..
    This same TV have about 12 years old hehe But is my "main" TV, work all day so thnaks god works for so long.
    But since have HD ready and is not that Bad, i like the TV, i manage to take out all the part's and start the search for the Fix's...
    I have Sound, and looks like the Back Lights are ok, i have made one Video to test the Back Lights, i think this is the Correct way to test it?
    https://www.youtube.com/watch?v=I37Up_6QFFI
    So, after this test i can only supose is the T-Con Board ( Model- V320B1-L01-C)?
    Before buy the T-Con Board, i mean a new one, i want to try fix.. I read on this forum about Fuses and the Voltage Regulator...
    But i have one Big problem, i cannot find in Portugal that Regulator (l1117LG-3.3)
    My Question is, there is another Regulator that can replace that one? Even over the Internet it's kinda hard to search for the "" l1117LG-3.3 "" The only thing i know, it's 3.3 volt's roftl..
    I want to give a try for my T-Con board before buy another.. I have made one call for someone close to me, and he said if i'm not rong, the l1117a-3.3 cab replace... But not sure... :/
    Thank you for any answer in Advance.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: LG 32lc3r / Sound ok Back light ok / No Picture
    on the tcon there will be a fuse it should have 5 volts dc on each side of the fuse use the tv chassis as a ground for your multimeter if you cant find it upload a good picture as we might need to zoom in too find it.
    Edit this should help you
    https://www.badcaps.net/forum/attach...7&d=1327107336
    • Xcat2008
      • Sep 2015
      • 25
      • Portugal
      Hello. thank you for the Answer.. Well i know where is the Fuse but i have only tested the condutivity not the Voltage.. But seems to be good...
      I have replaced already the Voltage Regulator, but only if few hours i can test it on the TV... My Dbout was that, if i could placed the regulator with another with another reference...
      The Man where i have purcased few minutes ago the Regulator told yes.. So i have place another more Strong, but of course with the sames Voltages.. The diferences is only on the mAh if i'm not Rong.
      I'm almost going blind lol... Because from what i eve read in this forum, if is not the fuse can be the Regulator.. So i eve tested the fuse and it's ok, changed the regulator, will test in 2 hours or so.
      • Xcat2008
        • Sep 2015
        • 25
        • Portugal
        Yes... Still the same... What do you guys suggest? Just buy a new/used T-Con board? Or make some more test's?
        I have Sound, back lights Working, but no picture
        Edit: I see a lot of T-con boards with the same Model number, but it's all the same? Because i see few Diferences between boards and not for the same brand... I Can buy for Example the Board T -Con from Samsung and will work on my tv?
          How about the pictures of the T-CON board?
          There are many Voltages on the T-CON board beside the 3.3V.
          What happen if you have one ribbon cable between the T-con and the LCD panel connected one at a time?
          The numbers on the barcode sticker are the one to use.
          Is this your board?
          http://www.shopjimmy.com/cmo-35-d003848-t-con-board.htm
          The LCD panel made by CHI MEI?
          • victor_cj
            • May 2015
            • 90
            • Romania
            First check the 6V from PSU at P203.
            The art of fighting without fighting
            • Xcat2008
              • Sep 2015
              • 25
              • Portugal
              @budm
              There is Pics from my T-con Board:
              And i will do that test in 5 mn...
              @victor_cj
              Thanks, i will do it also in few minutes.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Just out of curiosity what is that mark on top of U5 as can be seen in the first picture? It could be the dimple to mark Pin1 however it just looks different to the others.
                • Xcat2008
                  • Sep 2015
                  • 25
                  • Portugal
                  Well. I'm kinda Tired now of the TV, need to take a break lol...
                  But something happends...
                  As you guys know, i have changed the Voltage Regulator... The original is the ref: l1117lg-3.3
                  So i have today purchased another with the same specs.. The only diferent is he can take more mha... Ok..
                  At the fist time i have connected the T-con Board, and still the same... Like only Sound, but nothing about picture..
                  10 Minutes ago, doing this test "" What happen if you have one ribbon cable between the T-con and the LCD panel connected one at a time? ""
                  Half of the screen in this case left side was working.... And the right side just black...
                  So my first thinking, switch the ribbon cables... Now the 2 from the left go the right side..
                  After the change, the right side was working good lol And the left just black..
                  The only conslusions i can make... Is... The replace of the Voltage Modulator works... And i have for SURE at least 2 ribbons cables damaged ....
                  But is kinda strange, because the image is kinda sensitive, when i toucth the ribbon cables.. Sometimes only one the sides works, but when i toutch can turn Black again quickly...
                  Maybe because they are old, they are broke?
                  Where i can find cables to replace? To see if i can get my Tv Working...
                  Hope my English is fine
                  @dick_barton
                  Let me check more close, at this stage i need another coffe lol
                  Thank you guys.
                  EDIT: Almost Forgot...
                  @victor_cj There is no Cable on the P203, only in the others two.. But i have checked all the Wires and the Voltages are all goods... Only one cable where says "3v ON " show's me only 2v... If i'm not rong in the P202... Dunno is that can makes any diference... The others are all correct the voltages.
                  The Fuse from the T-con is 5V...
                    It sounds like you may have bad cables or bad contacts on the connectors, you can try contact cleaner on the sockets and on the exposed conductors of the ribbon cables.
                    At least now you are getting the pictures.
                    • Xcat2008
                      • Sep 2015
                      • 25
                      • Portugal
                      Yeah, i have applyed in the T-Con Board the Spray cleaner, but not on the Contacts..
                      But with all this thing.. Take the ribbons to the place, taking them out.. I lost the Blue plastic from 2 ribbons cables
                      So 2 ribbons cables is almost useless.... Because without the blue plastic on the ends, of course it does not make contact, which should ..
                      I cant find here in portugal Ribbon flat cables Any can show me where to find?
                      So the first thing now, is place new ribbon cables and clean the connections.
                      Thanks for the Help.
                      • Xcat2008
                        • Sep 2015
                        • 25
                        • Portugal
                        Anyone please confirm how many Pins, the Flat Ribbon cables have? 10? 20?
                        I find already where to buy, but i have the cables at home, so cannot see it right now.
                        And i want to buy it as fast i can to make my TV Working
                        • Xcat2008
                          • Sep 2015
                          • 25
                          • Portugal
                          Ok.. I cannot Find the fat Cables... All day calling here in Portugal for companys, and nothing... I can see only from Hong Kong.. But that takes ages to come to Portugal...
                          Anyone know where i can buy it? ( Flat Cable 45 Pin 0.5mm )
                          Please help me on this UK US hould be fine.. From Hong Kong or China takes like 1 mouth....
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            where you have lost the blue plastic cant you find a thin strip of plastic the same size and thickness then just hold it in the correct plcae whilst you close the connectors etc, as im sure the blue part just makes the ribbon cable a little thicker so presses on the contacts more?
                            • Xcat2008
                              • Sep 2015
                              • 25
                              • Portugal
                              Yes i can.. but doing that already broke the plastic part which closes the connection...
                              Well, thank you for all the Help.. I will buy from the Chineses.. Will take like 1 mouth, but better latter than never..
                              Thanks.
                              • Xcat2008
                                • Sep 2015
                                • 25
                                • Portugal
                                One question for the Expert's.
                                This T-Con Board is the same as this one? I mean if will work.
                                Main T-Con Board from the LCD ( Brand LG ):
                                Another T-Con Board ( Brand BUSH ):
                                • koby058
                                  vostro comes up with back light but no picture
                                  by koby058
                                  Hi people!!
                                  The owner said it showed bad picture once in a while (attached)
                                  I see that there is back light but no picture.
                                  I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                  Also attached schematic and BDV
                                  LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                  07-13-2025, 01:03 PM
                                • dronerat
                                  Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                                  by dronerat
                                  Hi Guys,
                                  This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                                  PSU: L48S6 FHS BN44-00807D
                                  T-Con: BN95-01937A
                                  Panel: CY-GJ048HGLVLH
                                  MB: NA (Currently as the TV is assembled and forgot to take picture)
                                  As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                                  It was sent to an authorized service for repairs and returned with the...
                                  05-15-2020, 08:03 AM
                                • kca
                                  Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                  by kca
                                  Hello all ~
                                  I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                  This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                  No picture. No sound.
                                  I tested all the voltages coming out of the power supply...
                                  10-12-2023, 05:23 PM
                                  Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                  by sam_sam_sam
                                  This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                  I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                  I am comparing them to a brand new one that I installed
                                  The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                  I going to let it run for several days before I remount back on the wall next to the...
                                  09-05-2024, 06:48 PM
                                • slimsoul
                                  Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
                                  by slimsoul
                                  Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
                                  I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
                                  I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
                                  The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
                                  03-12-2024, 03:55 AM
