Sanyo DP46840 Shuts off after a few seconds
  • marlboroa
    • Jul 2012
    • 59
    Hello, Im trying to get a sanyo DP46840 up and going. It comes on for a few seconds and then goes into shut down mode. When this happens the audio will go out first then the backlighs will turn off and the whole set goes into shutdown.
    I made a video showing the audio voltage dropping when this happens. I think it needs a new 13 volt IC chip.
    https://youtu.be/FG0lc_m6gJw
  • marlboroa
    • Jul 2012
    • 59
    Re: Sanyo DP46840 Shuts off after a few seconds
    Side note. If i turn the volume down the set stays on. So it has something to do with the 13volt audio circuit. I would say its the IC everyone has problems with.
    • CapLeaker
      Leaking Member
      • 8352
      Look at the PSon voltage. If it disappears, the PSU just shuts off. and I second the audio ic.
      • marlboroa
        • Jul 2012
        • 59
        Ok ill check that. Its been running for about 30 minutes just fine with the audio down. I can even turn it off and on just fine. now to find that little IC
        • riko 656
          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
          by riko 656
          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
          Laptop Model:
          • Model: Lenovo Legion Slim 5 16APH8
          • GPU: NVIDIA GeForce RTX 4070
          • Main BIOS chip size: 32MB
          • VBIOS chip size: 16MB
          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
          What I Have Tried So Far:
          1. I
          11-04-2025, 05:14 AM
        • chaos-theory
          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
          by chaos-theory
          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
          03-14-2025, 05:37 PM
        • riki_22
          ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
          by riki_22
          I’m working on an ASUS B5402CEA notebook.
          B5402CEA_MB_R2.2
          HA4YT LA-L861P
          REV:1B
          The board powers on, fan spins for a few seconds, then it shuts down by itself.
          I suspect the BIOS might be corrupted.
          Could someone please check and clean (repair) the attached BIOS dump?
          I’ve also attached a few photos of the motherboard for reference.
          Thanks in advance for your help!
          11-03-2025, 04:38 AM
        • APOPAP
          Panasonic National NV-M3 VHS Camera shuts down after some seconds
          by APOPAP
          Hello everybody,
          First post here. I have been reading posts here for some time now, but today I made my first account and post.
          The same question is also posted on another site, here it is:
          Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
          I tried connecting it to a Computer PSU (12.7v) but I get battery error...
          08-25-2025, 10:12 AM
        • tec3000
          Sony LED 65X9005A shuts down after few seconds - looking for help
          by tec3000
          Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
          I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
          03-20-2024, 07:29 AM
