Philips 46pfl5505d/f7 power supply question
  • krygods
    • Dec 2014
    • 257
    I have a philips 46pfl5505d/f7 with a bad power board. the part number for the power board is UPBPSPDEL004 (2950256100, M100325). I'm having trouble finding a replacement, but I have located one on ebay that looks to be identical part number is UPBPSPDEL002. My question is would the UPBPSPDEL002 work as a replacement for the UPBPSPDEL004?
    Here is a link to the original that I am trying to replace
    http://www.shopjimmy.com/philips-upb...unit-board.htm
    Here is a link to the one that I found that looks to be identical.
    http://www.ebay.com/itm/Philips-UPBP...item54186a5ee8
    Any advice would be greatly appreciated.
  • cmdrnsd
    • Nov 2015
    • CA
    Re: Philips 46pfl5505d/f7 power supply question
    Did you go ahead with the replacement of the board, or find somewhere that was still stocking the 004 model? I'm in the same boat after my TV decided to cook its board one evening while I was watching it, and I'd rather not fork out for a whole new set if I don't need to.
    • ajshoe
      ajshoe
      • Dec 2012
      • 477
      • usa
      believe the UPBPSPDEL003 will work in that 46 inch set. UPBPSPDEL003 is the power supply in the 55 set. Only difference is added power for the larger screen. (believe there are 2 additional mosfets in series on the UPBPSPDEL003 board. UPBPSPDEL002 won't work - its missing a connector for the additional backlighting unless you add the connector on the board. UPBPSPDEL003 is available
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        03-31-2024, 02:12 PM
        07-01-2024, 06:34 AM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
      • CMCM
        Russound CA4 Power Supply Repair
        by CMCM
        Hello Everybody,
        Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
        Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
        The outputs marked 12v and 20v are all measuring only 1v.
        The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
        The capacitors physically look clean (no bludgesor leaks) and...
        07-03-2025, 01:12 PM
