Panasonic tx-42x20b
  • Mr_Bodgit
    • Dec 2010
    • 47
    • doncaster
    Panasonic tx-42x20b
    Hi guys
    Just fixed this tv using another thread (no 15v supplying the 5v/3.3v) 10 flashesh of red led (sos)
    So I bridged the 0 ohm link/fuse that popped due to kids stiffing things into the sd card slot just to see if it turned on (tv was free so no loss if it damaged owt)
    Problem now is the screen has a stripe of red green and blue lines up it 1/8th of the way in from the right, 1/8th of the screen thick, it relates to the second connector on the buffer card (if I unplug it the lines get really dotty and scrambled but go back to RGB lines when reconnected, if I remove a different connector along the board I get a differerent 1/8th showing random dotty interference,
    Found a buffer card on eBay for £4 but wanted to check it's not a buggered screen first? Anyone know if it's the card or screen?
    Regards
    Richard
  • Mr_Bodgit
    • Dec 2010
    • 47
    • doncaster
    Re: Panasonic tx-42x20b
    No one know?
    • sordids999
      • May 2013
      • 2161
      • uk
      maybe a picture of the fault would help and hang fire some one who has a good knowledge with panasonics will reply when there free
      • Stanley1843
        Screen Display Vertical Multicolor Lines
        by Stanley1843
        Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
        06-29-2024, 11:54 AM
      • jeyoung12
        Samsung QN50Q60t lines on screen
        by jeyoung12
        Hi all
        I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
        My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
        This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
        It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
        So....i don't know what end of the C ribbon to work with...
        02-26-2024, 10:38 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
