ps-50q96HD Black Horizontal line
  • comptek
    • Aug 2013
    • 606
    • uk
    hi folks i have a ps-50q96HD it had a clicking power supply which is now resolved hence finding a solid Vertical (edited) black bar.
    stripped down assembly to check ribbons to re-seat them and came across a burnt connector on the buffer (E)
    on inspection there is still the track there on the ribbon just maybe needs a clean ? (see picture)
    also on the board there a 2 resistors labeled 470 have bubbled ? its not lacquer
    i have looked for a replacement buffer and can only find a
    LJ41-04733A REV R1.1 <<<<< replacement
    LJ41-04733A REV R1.0 <<<<< original
    would the replacement work or am i wasting my time and the screen has failed any comments or suggestions are welcome
    thank you
    Gary[/URL][/IMG]
    [/URL][/IMG]
  • tw2005
    • Oct 2011
    • 6458
    Re: ps-50q96HD Black Horizontal line
    As long as that E buffer looks the same and has the same connectors I'd say it'll be fine. Not so optimistic of that ribbon though. Any evidence of moisture, looks very grotty. I think the issue there is since this has burnt, then ribbon looks burnt which may lead to tracking between those pads. Does look black. If any of those embedded ICs on ribbon are damaged then that's panel damage , non repairable.
    Interesting that would cause a horizontal bar, I would have expected bad y-buffer and these do have a common PSU fault and upper buffers / ymain failures.
    The AA2 is probably the REV to search for when looking
    • comptek
      • Aug 2013
      • 606
      • uk
      *****AMENDMENT***** its a vertical bar not horizontal apologies
      • comptek
        • Aug 2013
        • 606
        • uk
        Many thanks for the input its a "vertical" bar not horizontal sorry for misleading you
        and it is very dusty there no sign of liquid though :/
        • tw2005
          • Oct 2011
          • 6458
          I'm going to say chances are slim then because it may very well be excess current draw due to the IC failure / shorted out IC potentially on that ribbon that caused the meltdown.
          . If you found a buffer dirt cheap it may be worth a gamble. The ymain and upper/lower buffer set would have reasonable value to sell or good chance you may pickup a another with good panel cheap? same boards used in the 50Q91 or C91 if you had that model
          you have not run this without that long alloy strip bolted across those lower address buffer boards, have you? instant death for those ICs. I did that once, destroyed a TV I just fixed the y section on.
          • comptek
            • Aug 2013
            • 606
            • uk
            Hi TW no i have not run it at all without the strip in place
            i found the board with a different rev number for £15 or best offer on ebay so like you said its worth a gamble can i test the ribbon and note measurements with the others if you know what i mean ?
            would that narrow things down?
            • tw2005
              • Oct 2011
              • 6458
              I got no idea but I'm thinking more towards panel damage the more I think about it. maybe wait for other opinions first. Comparing other resistance readings may prove useful. If it turns out to be shorted there I would think game over
              • comptek
                • Aug 2013
                • 606
                • uk
                ok thanks TW i will try measuring and see if theres anymore helpful and handy pointers much appreciated tw
                • comptek
                  • Aug 2013
                  • 606
                  • uk
                  just a quick update !
                  part finally cost £14 and i cleaned up burnt ribbon and tadah!
                  many thanks for advice and possible bad news about the screen it was worth a gamble
                  50" Samsung plasma up and running for 5 hours now no problems
                  [/URL][/IMG]
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Wow well done mate I would have wrote that off as panel ! Very well done hope you make a great profit
                      Nice - would have thought panel too having seen too many Samsungs go the same way.
                      You probably got lucky and it was just moisture damage.
                      • comptek
                        • Aug 2013
                        • 606
                        • uk
                        thanks mate
                        • comptek
                          • Aug 2013
                          • 606
                          • uk
                          thanks tom
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Honestly well done for not giving up I have seen it as welk on a few of these q96's
                            • comptek
                              • Aug 2013
                              • 606
                              • uk
                              i too started to think the worse but hey
                              thanks again all
                              • tw2005
                                • Oct 2011
                                • 6458
                                yeah, I would have thought no way the panel would be ok. Very surprised. If this thing shuts down randomly these get cracked joints on the PSU around the heatsinked FETs especially Va and Vs ccts.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  He has repaired the psu I think I told him what to do. Another very common fault is the shitty Y main failing then killing the buffer.
                                  • howardc64
                                    by howardc64
                                    Problem
                                    08-04-2024, 10:36 PM
                                  • Ihandyrepair
                                    Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                    by Ihandyrepair
                                    Hi guys
                                    I just started fixing 4k TV few months ago. so I am still learning a lot
                                    I got this tv from friend complaint is ghosting or horizontal lines on image.
                                    never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                    then it started to show the ghosting white image.
                                    I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                    it has 3 thin small boards at the bottom of the...
                                    12-05-2022, 04:18 PM
                                  • cubytus
                                    Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                    by cubytus
                                    Hi to all,
                                    I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                    I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                    Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                    01-10-2024, 01:26 AM
                                  • howardc64
                                    by howardc64
                                    07-24-2025, 05:17 PM
                                  • howardc64
                                    TCL 49S405 double image
                                    by howardc64
                                    LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                                    This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                                    06-23-2025, 03:20 PM
