Vx32l hdtv blank screen/no power
  • visioman
    • Aug 2015
    • 6
    Have a visio vx32l hdtv that has a blank screen
    when you hit power button the visio logo turns from amber to white then back to amber. I pulled the back off looking for blown capisitors, fuses, ect but didnt find any. I checked for voltage on the on/off pin to find 3 volts, checked the 5 volts pins to find 5 volts, checked the 24 volt pins to find it goes to around 9 volts when the power button is hit but drops drasitically, checked the 12 volt pins to find when the power button is hit i get around 3 volts but also drops drastically.
  • jetadm123
    • 2169
    Re: Vx32l hdtv blank screen/no power
    This video might help:
    www.youtube.com/watch?v=mWbrFcfazOA
    • visioman
      • Aug 2015
      • 6
      I get same readings as that video except I'm not sure how or what to test.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        The video speaks to capacitor C815. I'd check that first for a short if as you say getting the same readings as the video. That would mean B+ on the large e-cap remains at 166Vdc with Power Button ON and no 12Vdc, 24Vdc and PS_ON voltage dropping off.
        • visioman
          • Aug 2015
          • 6
          Large capacitor does have 168v when off and does go up to almost 400v when power button is hit
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • Chrissygizmo
            Panasonic TX-48CX350B backlights but white screen , blank screen
            by Chrissygizmo
            Hi all, I’ve got a problem I hope someone can help me fixi.
            I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
            01-11-2025, 03:18 PM
          • kotel studios
            Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
            by kotel studios
            Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
            State I got it in:
            Squealing from the PSU
            After logo I get a blank screen
            After 10 seconds of having a blank display w/ backlight the TV dies
            Give it 7-10ish seconds again and it starts to bootloop.
            What I did so far:
            Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
            Checked all voltage rails:
            5VSB - 4.8V
            AMP+13V - 14.4V
            13V - 12.98V (in manual 12V)...
            09-21-2025, 02:00 AM
          • dicky96
            HP Elitebook Screen blank - backlights but no image
            by dicky96
            Hi guys
            I'm trying to fix this laptop screen
            Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
            OK so I have the original screen which works but has lines across the bottom quarter of the screen
            I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
            04-28-2021, 07:30 AM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
