LG50 PC1 -oscillating RL-0n & AC-det voltage
  • Cornboats
    Dave
    • Oct 2010
    • 232
    • United Kingdom
    I'd given up with trying to sort this board out once but as I can't get a replacement I'm going for another attempt at finding the fault.
    The set came in with relays clicking. I found 11 bulged capactors on primary side which have been replaced.
    As the fault remained I removed board for bench testing and took flyleads from standby, rl-on, ac-det & earth so I could monitor the voltages. I also put a load of 2 x 60Watts incandescents across VS + earth.
    On start up with 2 x 100watt light bulbs in series with mains incoming, psu clicks on and off. Cycle repeats. During this time Standby voltage is a constant 5v. When relays click on AC-det voltage and RL-on voltage goes up to about 3v When relays go off both RL-on & AC det go down to 0v.
    I thought the RL-on signal came from the main board so why is this present? The relays shouldn't be trying to start anyway- should they??
    If AC-det is supposed to be 5V maybe this is the problem. If its developed from the same place as the 5V standby voltage then something is pulling it down.
    I would appreciate any help on this one.
    Photos uploaded taken from camera in VGA mode 16:9 1920x1080
    Re: LG50 PC1 -oscillating RL-0n & AC-det voltage
    Have you tried the optocoupler bridge "hack"? A failure in the AC detect circuit can cause issues, which mainfests itself as an oscillating on-off relay clicking sound. Search Badcaps for my posts on this matter.
    • Cornboats
      Dave
      • Oct 2010
      • 232
      • United Kingdom
      Tom thanks for your response. I did search on optocoupler bridge hack which only came back to my post.
      You posted a thread "LG 42PC1D plasma - clicking repeatedly" which refers to bridging ac-detetection optocouplers but no specific information. I've got a faulty board so I could just swop the couplers. Do you remember which ones they were? If not how would I trace the ones on my board? I'll try it if I can find them but theres about 9 on the board and some are under transformers.
        The optos aren't what go bad AFAIK - the circuit driving them does. Bridging them hides the problem with the AC detect circuit, although minor issues do exist as a result of this hack.
        • Cornboats
          Dave
          • Oct 2010
          • 232
          • United Kingdom
          Ok so can you elaborate a bit. What is AFAIK? How do I bridge the circuit?
            AFAIK = As far as I know
            The method is desribed in that thread - bridge the SECONDARY SIDE of the two back-to-front optocouplers.
            • Cornboats
              Dave
              • Oct 2010
              • 232
              • United Kingdom
              I can't find the optocouplers but found a reference in another reply you gave to bridging out ac-det circuit.
              https://www.badcaps.net/forum/attach...9&d=1371933868
              This looks like the bottom of a transformer to me. Do you think this is standby transformer T501?
                They will vary in position but there are two optos next to each other which are back to front, i.e. most send a signal from SECONDARY to PRIMARY (feedback) but these do the opposite from PRIMARY to SECONDARY (ac detect, monitoring etc.)
                • Cornboats
                  Dave
                  • Oct 2010
                  • 232
                  • United Kingdom
                  Tom thanks for taking the trouble to reply. I'll do some investigating. No one else has responded.
                  • Cornboats
                    Dave
                    • Oct 2010
                    • 232
                    • United Kingdom
                    Tom. I believe I found them. PC501 & PC502. Just out of interest I took the voltages before I bridged;
                    PC501 pin1=upto 0.32V- primary side
                    pin 2=upto 0.32V-primary side
                    pin 3=upto 4.48V-secondary side
                    pin 4= 5.03V steady-secondary side
                    PC502 pin1=upto 0.32V-primary side
                    pin 2=upto 0.6V-primary side
                    pin 3=upto 0.77V-secondary side
                    I soldered a bridge across pins 3 & 4 on both opto's. Switched on and exactly the same is happened. Fast clicking relays. Standy voltage is the only 1 thats steady at 5v. AC-det peaks at about 3v then dies in step the the relays. RL-on voltage is a copy of ac-det. Something I've been scratching my head over is the RL-on voltage. Doesn't this come from the main board?. I've got the board on the bench with only mains connected for testing( through a couple of incandescent lamps in series) so how come I've got voltage on the RL-on pin of connector P800?
                    Can you think of anything else I could try?
                    • ktmmotocross
                      Acer 515-54G badly burned Main power -After repair ACDET is pulled to GND when apply
                      by ktmmotocross
                      Acer 515-54G
                      DA0ZAWMB8G0
                      Board have badly burned Main power and second mosfet After repair ACDET is pulled to GND when apply power
                      i dont uderstand this. Charger ic BQ24780S
                      ACDET 6pin have voltage devider set to R1 110Kohm and R2 20Kohm. pin ACDET have 20K to GND. But when apply power R1 have 19V on one side and 2.3ohm on other side.
                      What is pulling my ACDET down when i apply power even without BQ ic...
                      12-02-2022, 12:03 PM
                    • wnlewis
                      Checking an oscillating fan motor
                      by wnlewis
                      I have an oscillating fan that quit working after getting knocked over one too many times (at least that's how it looks).
                      The first test was to check the off/low/medium/high switch. It appears that there is continuity through that; touched the switch contacts only.
                      Next, I replaced the capacitor with an exact duplicate. No success. The cap is a CBB61 two wire 3uF 250V foot mount.
                      What is a good capacitor tester?
                      I tried the shaft. It turns smoothly but I lubricated it anyway. Likewise the oscillating feature.
                      The fan is an older...
                      08-28-2022, 04:57 PM
                    • AudioGuy88
                      Info of Relays
                      by AudioGuy88
                      Hope this is the right forum to ask this.
                      I have a power supply from a very big audio amplifier which is 20+ years old.
                      I want to replace the relays in it.
                      Firstly, should I bother? Are relays reliable and should work for much more than 20 years?
                      If I should replace it as a precaution, please help me identify what the relays are.
                      There are 3 relays, 1 x black and 2 x white.
                      The white ones say 'FKD130P' which from a website tells me it's equivalent to NTE R53-1D30-24. If this is the case, then that's easy enough...
                      09-14-2021, 07:49 PM
                    • opethfan
                      GH5JJ TLA-K701 no charging no power no acdet
                      by opethfan
                      hi
                      i'm not skilled with laptop repair, i need some helps:
                      i don't have ACDET on PU1802 and in consequence i don't have ACDRV
                      please check pictures...
                      04-04-2025, 08:17 AM
                    • BrennoMaturino1
                      HP Pavilion G4 (DA0R13MB6E0) Doesn't power on, MAINON oscillating
                      by BrennoMaturino1
                      I got this motherboard from HP that wouldn't turn on, after testing it, turns out that the more accurate description would be that the power LED is flickering and it won't display anything, i got some backstory from this board, it wouldn't output video and another technician tried to reseat the LVDS cable with the laptop on hoping it would work, all it did was fry both the display and motherboard, magic smoke was released from the screen and cable, i thought the PCH was probably killed and went full shorted, i tested the PWM and it outputs a power good signal and no fault, but it quickly falls,...
                      12-02-2024, 11:44 AM
