Panasonic (TC-P55ST30) No power
  • tram704
    • Aug 2015
    • 12
    • US
    I have a Panasonic TC-P55ST30 that will not power on. I have no Flashing LED lights. Actually, I have no LED lights at all. I tried the unplug, hold power 10sec, then plug in again. No change. Removed back cover, No boards where grounded to case. Also, I have 120v entering main board. This is where I stopped. Any help on further troubleshooting would be appreciated.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Panasonic (TC-P55ST30) No power
    Please post pics of the TV with the back cover removed and close up Hi-Def pics of the PSU board and connectors.
    • tram704
      • Aug 2015
      • 12
      • US
      Not sure if this is what you were looking for but here are some pics. If not let me know and I will get some more. Thanks
      • tw2005
        • Oct 2011
        • 6458
        follow the guide, but I'd determine if 5Vstb is present, if so A board would be a suspect. SC boards can go short and cause 14 blink or locked solid LED. Should not affect 5Vstdby line though. the A board turns the front led on.
        • tram704
          • Aug 2015
          • 12
          • US
          Should I read 5vac or 5vdc? Sorry, for junior league question. I do have 5v dc. I moved to next step which was to disconnect a1 on a board and listen for relay click. Did this no click. Therefore replace a board. Just want to make sure about the ac/dc reading.
            It will be DC, everything on the power supply outputs is always DC.
            • tram704
              • Aug 2015
              • 12
              • US
              Thanks guys. Ordered board will let you know! Thanks again
              • tram704
                • Aug 2015
                • 12
                • US
                "A" Board fixed my problem. Thanks for the assistance.
                  Nice, thanks for the update.
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • WVUfan
                    PS5 EDM-033 One Beep,No Lights, No Power Troubleshooting Help
                    by WVUfan
                    hello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
                    08-11-2025, 01:12 PM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
