Hitach 50s601 screen issue
  • topfli8979
    • Oct 2012
    • 311
    Been working with this plasma for a while now, picked it up would not power up without going into protection. Found the lower sdr board to be faulty. Replaced with know working sdr and tv powers up fine with picture. BUT the lower half of the screen is distorted, seems to have some moving lines running through it. If this was a Lcd I would chalk it up to a bad panel, but being a plasma I'm not so sure. Would faulty y sustain cause this issue?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Hitach 50s601 screen issue
    Looks like a buffer fault or loose connectors on the lowwer y buffer reseat them.
    • topfli8979
      • Oct 2012
      • 311
      I have tried reseating the connectors, even tried another complete buffer same effect.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Hmm possibly panel fault then unfortunatly.
        • mmartell
          • Oct 2013
          • 3189
          Can you swap upper and lower buffers on this set ?
          • wizard13
            Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
            by wizard13
            I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
            I have checked the forum and the available documentation but could not find a solution specific to my issue.
            • Brand & Model: Dynabook Satellite Pro C50D-B-100
            • Part Number (P/N): PYU13E-00C00PFR
            • Serial Number (S/N): 22028896H
            • System Configuration (SC): A1PYU13E1127
            • Motherboard Model: IP3_ACN16_MB_V21_20211222A
            • Power Input: DC 19V –
            02-28-2025, 02:43 AM
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • cloudy
            HELP - Contrast/brightness issue with subtitles on screen
            by cloudy
            Hi everybody
            Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
            Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
            Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
            It occours both on ubuntu and windows...
            01-01-2023, 05:12 PM
          • ScHAmPi
            Samsung UE48JU7000 screen issue after backlight replacement
            by ScHAmPi
            Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
            I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
            07-15-2024, 05:41 AM
          • Alicat
            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
            by Alicat
            Stopped by this site trying to fix my parents Panasonic Plasma TV.
            Model number is TH-50PZ85U
            Power comes on and the red power light stays on solid.
            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
            I also hear a few clicks.
            I also think my parents said there was a thunderstorm and the TV failed after that.
            Section 6 in the service manual talks about power and no screen,...
            10-30-2024, 10:09 AM
