Sony KLV-32M1 flickering/popping
  • Mike Toole
    • Aug 2010
    Hey gang,
    Not a regular, but a couple of years back you folks were a huge help in getting a couple of discarded 19" LCD monitors with bad caps repaired. (Worked like a charm, monitors are still in service!) I found a Sony 32" LCD TV (model number's in the title) on the curb near my house. Oftentimes finds like these are broken for good, but just as often they can be repaired or rehabbed. When I got the TV home and turned it on, I was delighted to see that it powered right up! I was less delighted to see how it handled DVD video and audio (video in link):
    https://vine.co/v/ehQzzb1j6qd
    As you can see, the TV displays the DVD audio and video fine, but with a steady flickering and popping. I'm no expert, but I did some googling and reading, and it sounds like the issue here MIGHT be the power inverter board. I'm _just_ handy enough with this stuff to replace that item, I think, but I want some feedback from folks who are a bit more experienced.
    Any ideas on the issue here? Inverter board? Capacitors? Or something more pervasive and difficult to fix. Thanks as always for any suggestions!
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • LINCKODE
    Sony Bravia KDL-37S5600 inverted color and flickering
    by LINCKODE
    Hello!
    I have a Sony Bravia(the specific model is in the title) that is exhibiting the following behaviors:
    - Color inversion on the whole screen(or rather it has trouble displaying gray and black correctly)
    - Static-like flickering on the dark parts of an image(it will flicker between black and white on some dark parts of an image)
    - Bad image detail/sharpness
    These issues switch between each other from time to time.
    After consulting some online resources and the LCD TV troubleshooting guide I found on this forum, I believe I am...
    12-14-2022, 08:34 AM
  • reessi
    ACER BM320 Monitor - Horizonal Flickering Lines After a While
    by reessi
    The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
    They are black on the right and gradually fade to nothing on the far left.
    They start either after 5 mins or up to 2 hours after so annoying for testing.
    They flicker continuously very fast! With a slight pause milli-second every second.
    Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
    I tested each half by removing the first the left flex from...
    06-03-2025, 09:58 AM
  • storexxm
    Sony 65AG9 Oled Flickering
    by storexxm
    https://youtu.be/lIy3wANcWKA
    Does anyone have an idea what can cause this "flickering" i ve never seen something like this before on an oled TV
    Hope someone can help me :-)
    08-16-2023, 08:55 AM
  • dkneyle
    Sony KDL-46HX850 Can't upgrade/update firmware
    by dkneyle
    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
    09-25-2024, 10:44 PM
