Samsung PN51E450A no picture
  • cmorton
    • Jul 2015
    • 10
    • US
    I have a Samsung plasma PN51E450A1FXZA that will not turn on. The stand by light is on and will flicker 5 or 6 times when you try turn power on, but no picture will appear. If you wait another 5-10 minutes the chime will sound and the stand by light comes back on.
    I've replaced the power board, XY board, and Y buffer. It still does the same thing. Could anything else be causing the problem...any ideas on how I should proceed? I do not have a multi meter.
    Thanks,
    Chip
  • sordids999
    • May 2013
    • 2161
    Re: Samsung PN51E450A no picture
    Posting photos showing the parts of the back the TV will proberly help you more with fixing your fault
    • cmorton
      • Jul 2015
      • 10
      • US
      Ok, I inserted a picture of the back of the tv. I can include close ups of particular parts later today if need be.
      Thanks,
      Chip
      • Hamie
        • Apr 2014
        • 1383
        Check voltages VS VA located on the power supply.
        Vsc (vscan) located on the y-sustain.
        Ve located on the x-main.
        Should match your panel sticker
        • cmorton
          • Jul 2015
          • 10
          • US
          Ok, I was able to pick up a multimeter. Here are the results:
          vs: 201 on sticker, 201 on reading
          va: 58 on sticker, 58 on reading
          vsc: -180 on sticker, -186 on reading
          ve: 78 on sticker, 80 on reading
          A little more info that may or may not be helpful. The unit is just over 2 years old and there were no problems leading up to this. There is no smoke or burning smell. The led light in the back is strong...blinks every second. I've replaced the power board, xy board, and y sustain since those seemed like the most likely culprits, but nothing changed. I've attached a few more photos. If you need any more let me know. Thanks for helping.
          -Chip
          • Hamie
            • Apr 2014
            • 1383
            Well with those voltages the panel must be glowing?
            Darken the room and see if it is.
            On the control board (small board in the center of the TV.)
            Youll find a small black square with 4 pins sticking up.
            The should be numbered 1-4, short out 3 and 4 with a bit of wire or crocodile clip etc.
            Disconnect the LVDS cable ( the wire that connects this board to the main av board)
            If you get test patterns then the mainboard is your problem.
            • cmorton
              • Jul 2015
              • 10
              • US
              It doesn't appear the control board for this unit has the 4 pins sticking up to run this test. I attached a pic in case I missed something.
              Thanks,
              Chip
              • Hamie
                • Apr 2014
                • 1383
                It does it has 4 holes instead. Just connect holes 3 and 4.
                  Is the panel free of cracks? Even a small one on the edge can stop one of these sets from working.
                  • cmorton
                    • Jul 2015
                    • 10
                    • US
                    I don't see any cracks anywhere. Also, I'm having trouble locating where the 3 and 4 hole are.
                    Thanks,
                    Chip
                    • Hamie
                      • Apr 2014
                      • 1383
                      • cmorton
                        • Jul 2015
                        • 10
                        • US
                        Ok, I disconnected the lvds cable and put a plain wire through holes 3 and 4 (see picture). When I turned the tv on I did not get the test patterns...just the same as before. Standby light blinks 6 times, goes out, and no picture.
                        Thanks,
                        Chip
                          Do you have Vs and Va during this test?
                          • cmorton
                            • Jul 2015
                            • 10
                            • US
                            Yes, I do.
                            Thanks,
                            Chip
                            • cmorton
                              • Jul 2015
                              • 10
                              • US
                              Would it be worth a try to replace the main board or the control board or is this most likely some kind of issue with the panel and I'm stuck with an expensive piece of trash?
                              Thanks,
                              Chip
                              • Hamie
                                • Apr 2014
                                • 1383
                                im unsure if your jumper is making a suitable connection for test patterns. those are copper pads id solder it directly.
                                • cmorton
                                  • Jul 2015
                                  • 10
                                  • US
                                  Re: Samsung PN51E450A no picture/update
                                  I replaced the mainboard and the tv powered up just fine. Seems to be working properly now!
                                    09-07-2024, 05:50 AM
                                  • TR103
                                    by TR103
                                    - it keeps rebooting
                                    01-22-2025, 04:12 PM
                                  • JJAAMM
                                    by JJAAMM
                                    Problem
                                    07-06-2023, 06:01 AM
                                  • Mgiffune
                                    by Mgiffune
                                    06-09-2024, 10:28 AM
                                  • Dodgethis
                                    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                    by Dodgethis
                                    Hello all,
                                    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                    09-11-2024, 07:39 AM
