lg 42lc5dc
  • oldhippie100
    • Dec 2013
    • 29
    • usa
    lg 42lc5dc
    Had a question on replacing bad Caps. my power board has 4 or 5 bad was just going to replace just them.however a buddy recommended replacing them all.found a guy selling the whole kit for my power board. my question is do i really need to replace them all? i mean my motto always has been if it aint broke don't fix it..any suggestions?
  • Hamie
    • Apr 2014
    • 1383
    Re: lg 42lc5dc
    No you don't need to replace them all.
    Replace the domed ones, and it's recommended to replace any that are in proximity with the ones that failed.
    Use better caps, panasonics, Ruby's etc.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8325
      Re: lg 42lc5dc
      No you don't "need" to replace them all. That is very easy to say for someone that has proper equipment to check capacitors. However... caps can "look" good and still be bad. You may be lucky by replacing only the visibly bad caps, but you may be not. So, for anyone that do not have any way of checking ESR I recommend to replace them all. Caps are cheap, it isn't like you would be spending big $$$
      • oldhippie100
        • Dec 2013
        • 29
        • usa
        Re: lg 42lc5dc
        thanks guys.for the advice.the kit i found is $17 replaces all 19 of them. here is the link to the kit.
        http://www.ebay.com/itm/LG-42LC5DC-L...item4d094fe4b7
        looks like all good quality caps in the kit
        • Baste
          Replacing a bad Cap with higher value.
          by Baste
          Hello experts people,
          First time poster but lurking the Forums for few days now. I'm a beginner hobbyist who's trying to fix what ever I can and learned along the way. Right now what I have is a busted 58inch LCD TV with backlight issue. Long story short, I kinda found the issue (or atleast on the right track) it's on the power board with bad caps (broken pin). It seems an easy fix, just replace it with the same one and away it goes, but for whatever reason I cannot find the exact value in my place or online store in my country. The bad Cap is 39uf 450volts in parallel. The...
          09-22-2025, 01:56 AM
        • caspian
          What Zener Diodes on a Linear Power Supply
          by caspian
          Dear members,
          I have a linear variable power supply with unknown brand name that I used for voltage injection.
          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
          In addition, I discovered that its zener diodes are defective.
          I can replace the burned transistors.
          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
          Therefore, I cannot replace the zener diodes.
          I do not want to test the zener diodes in a test circuit to discover their model or value.
          no schematics are available...
          05-26-2025, 12:38 PM
        • Peter Toropov
          GL702VM not charging/unable to power on
          by Peter Toropov
          Disclaimer
          This is my first time at attempting such repair and troubleshooting, so I apologize in advance if I do something wrong or misunderstand some things. I will attempt my best to research more information to better understand everything.
          Issue
          Laptop was unable to charge the battery, but was able to boot up without it, when powered on it had unstable CPU clocks while under load due to sudden throttling when reaching 70C. Upon visual inspection, a blown capacitor PCI8601 was discovered near MOSFET PQH8601, which has been replaced. The MOSFET...
          03-11-2024, 11:43 AM
        • Reintar
          Dell Inspiron 15 7567 (LA-D993P) - No power after replacing blown inductor and shorted mosfet advice needed
          by Reintar
          First of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
          One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...
          08-30-2024, 06:13 AM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
