samsung le32a456c2d flickering/blinking issue
  • mattoxx
    • Jul 2015
    • 7
    • united kingdom
    Hi. My samsung le32a456c2d has the flickering/blinking issue. You can see it on video I uploaded.
    Power board is BN44-00214A
    I found that similar problem was solved by cutting the jumpers. Can I use same procedure here? What jumper to cut? What seems to be an issue?
    My video showing problem
  • mattoxx
    • Jul 2015
    • 7
    • united kingdom
    Re: samsung le32a456c2d flickering/blinking issue
    Any ideas guys?
    • sordids999
      • May 2013
      • 2155
      • uk
      Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
        +1, beside, did you remove those bad brown glues?
        • mattoxx
          • Jul 2015
          • 7
          • united kingdom
          Hi guys, I just found out that flickering is related to backlight. If backlight is set low then everything is fine. The frequency(speed) of flickering goes up as I increase it.
          http://www.imgup.cz/images/2015/08/0..._172053019.jpg
          http://www.imgup.cz/images/2015/08/0..._172112861.jpg
          http://www.imgup.cz/images/2015/08/0..._172100952.jpg
          http://www.imgup.cz/images/2015/08/0..._172108002.jpg
          • mattoxx
            • Jul 2015
            • 7
            • united kingdom
            I did some measurement on power supply on backlight set on both low and high.
            low backlight: 24V = 20.7v
            12v = 10.5v
            high backlight: 24V = jumping between 19.5 - 20.7v
            12v = jumping between 9.5 - 10.5v
            • Kjell
              Samsung Series 9 - BIOS issue
              by Kjell
              After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
              Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
              08-01-2025, 09:15 AM
              09-07-2024, 05:50 AM
            • Nairolf
              Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
              by Nairolf
              I have a Samsung DM32D display.
              When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
              Here’s what I have tried so far:
              1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
              2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
              3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
              From these tests, I suspect the problem might be on the mainboard. Could anyone...
              Yesterday, 03:47 AM
            • Indie
              Samsung TV LA46B550K1R flickering issue, so near yet so far
              by Indie
              I have a samsung tv (2009, works well) apart from an imminent flickering issue for some time.
              Model: LA46B550K1R
              Model code : LA46B550K1RLXL
              Ac:100-260 V 50-60Hz, 240W
              Power supply circuit: BN44-00265B
              I read through the forums and found other Samsung models both 46, 55 inches , old and new with similar issues. Two things stood out:
              1. eco setting in tv was recommended to be switched off
              2. Jumper number JP852 was recommended to be cut off.
              Now before opening the tv i tried playing around with the...
              09-24-2020, 01:44 AM
            • vincentedel
              Samsung SyncMaster 740n Phase Control Issue
              by vincentedel
              I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
              I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
              04-22-2025, 12:33 AM
