Re: Soniq E40W13C-AU TV Stuck on standby
Hey guys,
my TV has the same problem. ausvantage which one of the three voltage regulators did you end up replacing? and do you still have the spare ones?
Is your TV still working?
Cheers
The tv I picked up was stuck in standby . I replaced the same voltage regulator as described above. The type I replaced it with was ams1117 adj ht2438 got about 10 of them delivered for $3 .
Tv works perfect now no other issues at this stage. If anyone needs these regulators I have many spares.
Thanks immensely to the above contributors that made this fix easy.
CheersLeave a comment:
Hi I've checked all the other regulators including the one I replaced. All seem to be showing the correct voltages. I'm gonna try and replace the caps on the main board. See if that helps.Leave a comment:
I think I'll closed this thread as the original problem was solved. The TV is no longer stuck on standby and the fix was to replace a faulty ADJ LDO on the main board. Thanks budm for your assistance.Leave a comment:
No the menu does not seem to work at all. The problem has evolved, if you can say that, so instead of bad picture, the TV just keeps on restarting. So it will turn on, picture is good, then restart.Leave a comment:
when it does that, do the osd menu's still work?Leave a comment:
Sorry does anyone have any idea what I should test or have a solution for this problem? Thanks you.Leave a comment:
Hi Budm, thanks for your advice I replaced the ADJ LDO IC and the TV finally turns on. It behaves while no input is in but when I plugged in the chromecast, it behaves for about 5 second and then the image is distorted. Please refer to the pictures. ThanksLeave a comment:
Cheers thanks budm. I've ordered the part and will update you on the result.Leave a comment:
Good, go ahead and replace that ADJ LDO IC with the 0.79VDC output then. I would get more than one in case it gets damaged.
'GND - 3 = Increase / decrese in ohms (possibly due to the capacitor it is attached to?)' Can be due to some left over Voltage that the caps did not completely discharged.
It is good to always check when the readings do not make sense, you can use Ohms law to see that what you are seeing is impossible.Last edited by budm; 07-24-2015, 09:19 PM.Leave a comment:
BM1117-3.3 (voltage Regulator Number 1)
Between GND - Pin 1 = 0V
GND - Pin 2 = 3.295 V
GND - Pin 3 = 5.17 V
Between GND - 1 = 0 Ohms
GND - 2 = 341 ohms
GND - 3 = 4 Ohms
BM1117-ADJ (voltage Regulator Number 2)
Assuming pins are numbered left to right:
Between GND - Pin 1 = 141.4 mV
GND - Pin 2 = 0.790 V
GND - Pin 3 = 5.18 V
Between GND - 1 = 102 Ohms
GND - 2 = 454 ohms
GND - 3 = 1k Ohms
OK, one thing for sure is that the one with 0.79V output on pin 3 is not right so I would replace it.
But the other one that shows 5.17VDC on pin 3 but it has 4 ohms to GND, that has to be error in resistance reading since @5.17V with 4 Ohms you are talking about 1.3A of current with >6 Watts of power dissipation! That has to be an error.
GND - 2 = 341 ohms
GND - 3 = Increase / decrese in ohms (possibly due to the capacitor it is attached to?)Leave a comment:
GND - 2 = 341 ohms
GND - 3 = 4 Ohms
GND - 2 = 454 ohms
GND - 3 = 1k Ohms
But the other one that shows 5.17VDC on pin 3 but it has 4 ohms to GND, that has to be error in resistance reading since @5.17V with 4 Ohms you are talking about 1.3A of current with >6 Watts of power dissipation! That has to be an error.Leave a comment:
"Between GND - 1 = 0 Ohms
GND - 2 = 341 ohms
GND - 3 = 4 Ohms"
This one does not look right, it is showing that the input pin has only 4 Ohms of resistance. Is this the one that has pin 2 output of 0.79V but pin 3 input pin has 5V input?
I would remove it and then do the resistance testing again on the pads of the board where the IC was soldered to see if the low resistance will go away.
Either one of those two will work as long as they are adjustable type.
GND - 2 = 341 ohms
GND - 3 = 4 Ohms
GND - 2 = 454 ohms
GND - 3 = 1k OhmsLeave a comment:
GND - 2 = 341 ohms
GND - 3 = 4 Ohms"
Either one of those two will work as long as they are adjustable type.Leave a comment:
Hi budm, thank you for your assistance. I measured the resistance as you have suggested and here are the results:
Voltage Regulator 1 (shown in picture 1)
Assuming pin number from left to right.
GND - 2 = 341 ohms
GND - 3 = 4 Ohms
I have also checked the capacitor, with a multimeter set to ohms, that is connected directly to Pin 3 and it seems to be charging and discharging fine.
Voltage Regulator 2 (shown in picture 2)
GND - 2 = 454 ohms
GND - 3 = 1k Ohms
So because of these results are they faulty?
If so I can't seem to find any supplier in Australia for the BM1117 series, can I use the LM1117 series instead?
Their datasheet:
BM117
LM1117
They both have similar specs except the LM1117 series has a max output current of 1.5A.Last edited by zantesu; 07-24-2015, 06:08 PM.Leave a comment:
"Between GND - Pin 1 = 141.4 mV
GND - Pin 3 = 5.18 V"
So you have 5V at the input pin, and 0.79V at the ADJ pin, so if the IC is OK then you should have .141V +1.25Vref = 1.39VDC at pin 2, so you do have bad regulator since you are getting only 0.79VDC. You should take the resistance reading (no AC to the TV of course) between pin 2 and Ground to see if it shows low resistance, it can also have bad filter cap that is connected to pin 2 so you need to check that also.Leave a comment:
Hi I think you posted this in the wrong thread. There's a welcome thread for new members.Leave a comment:
Hi, my name is Cherry. I am new here. Nice to see you. I am from China. And now I am working in an electronics company named NOD Electronics.Leave a comment:
So I did what you said, and the backlight and screen turned on (and stayed on). However, nothing came up on screen.
It seems I'm still stuck on standby because the red LED at the front of the TV did not change; it just stayed lit up the whole time even though I was pressing buttons on the remote and the controls on the side of the tv.
I also measured the voltages across that discoloured voltage regulator (BM1117 - ADJ) and these are my findings.
I also measured the other voltage regulator (BM1117 - 3.3)
Not sure if the both info would help. What should I look at next?
by Michael LongI had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
Dead / No Power / No Standby Light results after power company had three
consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized... -
by LoagzHi, I'm hoping someone can point me in the right direction....
I have a S55V14B TV and it suffered a board failure. Main board part number: 222-655036003-30. I couldn't find a board with the exact part number so I've used what looks to be the same board however the part number is slightly different. 222-655036002-30.
After installing the main board the stanby light came back on, however it wont turn on. I spoke to Soniq Australia and managed to get a copy of the firmware but no service manual. They don't have one. I asked about the different part numbers but they... -
by samsonnI've got a 55" Soniq LED TV which is stuck in standby mode (initiator LED on, but no picture/sound/backlight). It will intermittently start working again for a few days or weeks, but it has been months since the last time it turned on. I've seen a lot of similar issues with Soniq TVs that were fixed by updating the firmware, but I need to turn it on to update the firmware so no luck there.
I've taken the back off and visually inspected it but everything looks fine. No exploded capacitors or signs of overheating etc. All of the 1117 regulators on the main board were outputting... -
by noinimodNo standby red light, nothing
This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
Disconnected JK3 power board from main board, checked voltages on all the pin outs
At a few pins I can see the power supply providing 19.5V to the main board
Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,... -
by StuntHi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
screen that's it and stuck there. I left it until the following day and i still...09-02-2025, 01:51 PM - Loading...
