Panasonic TC-P50S30 repair/mod
  • fullsmoke
    • Jun 2015
    • 9
    Hello all! I'm very new to this forum and am very grateful for this forum otherwise I would have never figured out how to repair my 4 year old P50S30 plasma!
    Everything started with the 7 blinks of death. Google had me believing it was my SC board but after more reading and searching I discovered it was actually my SU board that was bad as my SC passed the SC50 jump test. I used ricosavy's and tw2005's method to confirm my SU was shorted. I also used the P50S30 service manual. I picked up a used SU board off ebay, which are not cheap but I got lucky.
    Now, I was wondering how to try to keep this from happening again so soon... I noticed that the GT/VT/ST models all had heat sinks on their SU/SD boards, so I measured some temps of the IC chips on my S30 and ended up with the temps in the images attached (varied from 94-106f after 15 mins of power). The temps were measured at about 76f, room temp. FWIW, the SC board reached some high temps (up to 126f after 15 mins of power).
    I decided to add small aluminum heat sinks to the IC chips (except for bottom 2 on SD because I only have 10 sinks) to help with the heat generated, thinking that's why Panasonic added them in higher end models. I also used medium strength Loctite on the SC/SD/SU/SS ground screws. There were one or two loose screws on the SC board!
    Anyway, I just wanted to say thank you guys and contribute what little info I have!
    Thanks!
    FS
  • fullsmoke
    • Jun 2015
    • 9
    Re: Panasonic TC-P50S30 repair/mod
    Update: The IC chips run about 10-15f lower now. The bottom two (without heat sinks) only get up to about 88-92f.
    • tw2005
      • Oct 2011
      • 6458
      Nice.
      Anyway even if the Sc goes it's a fairly easy repair but lets hope the buffers survive for you .
      • fullsmoke
        • Jun 2015
        • 9
        Originally posted by tw2005
        Nice.
        You mentioned to me there are people repairing SU/SD boards? Has anyone had success with these? I see some eBay listings for SU/SD repair but they aren't cheap.
        FS
        • bwilliams60
          • Aug 2014
          • 109
          You mentioned that you had a copy of the service manual. Where could i get a copy of this from? Thank you in advance.
          • tw2005
            • Oct 2011
            • 6458
            I could make this easy for you but I won't.
            1. search the model number in the forum, second item in the search i did had both the manual and the ST30 series troubleshooting guide as well.
            2. front page sticky's ": TV Repair Reference Library" have some good tips
            3. Elektrotanya
            4. Google
            • Andre Gilbert
              by Andre Gilbert
              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
              11-20-2024, 08:52 PM
            • AquaMan Ua
              by AquaMan Ua
              05-17-2025, 09:40 AM
            • SFETech
              Panasonic P50S30 SC board pins 1-3 Short
              by SFETech
              I'm aware pin 3 is ground, but pin 1 is shorted to pin 3 even when not mounted to the machine. It's happening on the original board as well as the ordered replacement board. TV is giving 14 blinks. I'm trying to troubleshoot the machine and thought I'd figured it out when I found a pin that wasn't labeled as ground (Pin 1) shorted to ground, but now I'm just trying to verify if I have two boards with the same fault or if that's how the board is designed and I'm looking in the wrong area.
              04-14-2022, 08:11 AM
            • stecos
              Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
              by stecos
              Hi everyone!
              For my passion for technology I'm now collecting several...
              11-28-2022, 11:39 AM
            • aa10aa10
              Panasonic Toughbook CF-33 mk1 BIOS repair
              by aa10aa10
              Good day,
              I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
              I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
              01-21-2025, 06:13 AM
