I would appreciate some help. My television comes on, the screen lights for a second and the set goes to standby. I have replaced the eeprom, checked the 1v8 regulator and all of the lamps light. Any ideas?
Umc 3969ggb
I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old... -
by dmccul2698Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
1). Understand the schematic and check the connections between the EEProm and DSP
2). Check the functionality of the EEProm
I don't know if this is the unit's problem but it's a place to start.
I have little to no electronic experience...6 Photos-
by disorderhello,
i have a hp display 2311 to repair, totaly dead
on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
thank you-
by edgarmg15Hi everyone
I´m trying to repair a TV Vizio E320-A0 that I found in the street
The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)... -
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... - Loading...
