Panasonic HT-P54V20A Fuse F501 open
  • Michaeld4500
    • Aug 2014
    • 10
    Panasonic HT-P54V20A, Power supply board ETX2MM807MSL Fuse F501 open, no standby led, tested C501 14.05nf, D501 0.6Mohms across the AC pins and 8.40Mohms. I am going to replace F502, C501, D501.
    It there any other components I should test, replace ?? Thanks
    Drawing is from HT-50v20 manual.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic HT-P54V20A Fuse F501 open
    your TV that broke or a broken TV project? Can't say I've read much on P board failures on these yet. Was it a power surge / lightning hit?
    I'd be checking the mosfets on the PSU too. Fuses usually blow due to a short
    I'd check RF601 which is a fusible resistor, will look like a ceramic resistor, check the bridge rectifier for short.
    I'd also post some images top and bottom for everyone to see.
    I don't have much experience with the P boards but i do have the 50" version P spared
    I would check out the SC board while you're having a pke too. check SC2 across the pins for short, check Q661 on the Sc also see if shorted.
    • Roj.
      Old enough...
      • Feb 2015
      • 17
      Hello Michael4500
      Do you have a manual for TH-P54V20A or is your pdf of the P-Board from a related manual?
      Roj.
      Old enough to know better
      • Michaeld4500
        • Aug 2014
        • 10
        Hi
        I only have the Ht-p50v20a manual, the TV was a freebie, the owner said they were unable to turn it one day.
        I will check those parts as suggested and reply soon. Thanks for the help
        • corrize
          A funny fuse story – Lumix LX100 II
          by corrize
          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
          10-19-2023, 09:58 AM
        • BigPete
          Panasonic Heatpump Dryer Repair
          by BigPete
          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
          Unfortunately the whole machine has to come apart to fix it.
          I have...
          11-01-2025, 06:40 PM
          Acer Extensa EX2519-C501 Notebook 15 Specification for Upgrade or Repair
          This specification for the Acer Extensa EX2519-C501 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EX2519-C501 boardview and EX2519-C501 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
          09-06-2024, 06:00 AM
        • Andre Gilbert
          by Andre Gilbert
          11-20-2024, 08:52 PM
        • jesterace
          Samsung UE46ES8000 Blown fuse but no other signs of short
          by jesterace
          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
          09-11-2024, 03:14 PM
