Panasonic HT-P54V20A Fuse F501 open
  • Michaeld4500
    • Aug 2014
    • 10
    Panasonic HT-P54V20A, Power supply board ETX2MM807MSL Fuse F501 open, no standby led, tested C501 14.05nf, D501 0.6Mohms across the AC pins and 8.40Mohms. I am going to replace F502, C501, D501.
    It there any other components I should test, replace ?? Thanks
    Drawing is from HT-50v20 manual.
  • tw2005
    • Oct 2011
    • 6457
    Re: Panasonic HT-P54V20A Fuse F501 open
    your TV that broke or a broken TV project? Can't say I've read much on P board failures on these yet. Was it a power surge / lightning hit?
    I'd be checking the mosfets on the PSU too. Fuses usually blow due to a short
    I'd check RF601 which is a fusible resistor, will look like a ceramic resistor, check the bridge rectifier for short.
    I'd also post some images top and bottom for everyone to see.
    I don't have much experience with the P boards but i do have the 50" version P spared
    I would check out the SC board while you're having a pke too. check SC2 across the pins for short, check Q661 on the Sc also see if shorted.
    • Roj.
      Old enough...
      • Feb 2015
      • 17
      Hello Michael4500
      Do you have a manual for TH-P54V20A or is your pdf of the P-Board from a related manual?
      Roj.
      Old enough to know better
      • Michaeld4500
        • Aug 2014
        • 10
        Hi
        I only have the Ht-p50v20a manual, the TV was a freebie, the owner said they were unable to turn it one day.
        I will check those parts as suggested and reply soon. Thanks for the help
