Westinghouse lvm-42w2 only standby voltage
  • ryanfan03
    • Apr 2014
    • 45
    So my buddy gave me this tv to look at because it would not turn on. Specifically when it is plugged in the light on the front (a ring with a w) is lit. Once the power button is pressed the light goes off and the set clicks with nothing on the screen. I opened the set to test voltages from the power supply and only read the 5v standby voltage. I then removed the board and tested the components i could test (diodes fuses etc) and came across these readings on the two (i think) mosfet transistors.
    Q302
    Black lead. Red lead. Reading.
    Source. Drain. 1
    Source. Gate. 1
    G. D. 1
    G. S. 578
    D. S. 426
    D. G. 1
    Q301
    Source. Drain. 1
    Source. Gate. Starts at 1900s and steadily falls
    G. D. 1
    G. S. 086
    D. S. 427
    D. G. 545
    I havent looked at a schematic or a data sheet on them (they are buried under a heatsink and i cant read the numbers). Is it a good assumption that the q301 transistor is bad and needs to be replaced? If so it is going to be a pain but a fun challenge i guess
    Doing this on the side to make some extra money for my daughters dance competition.
    Re: Westinghouse lvm-42w2 only standby voltage
    It may have Gate/Source resistor in parallel. Are those reading in Diode mode or Ohm mode, what do you get in Ohm mode?
    How about the command signals (PS-ON, BL-ON, etc.) from the main board to turn on the power supply? How about the DCV on the main filter cap when the TV is not turned on and when it is turned on?
    How about good clear pictures of the whole backside of the TV and the boards?
    We do not have the TV in front of us to look at to see what the setup is.
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • x_orange90_x
      Samsung UN55KU6300F no standby voltage
      by x_orange90_x
      I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
      Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
      05-21-2025, 09:59 PM
    • Bad_IC
      Philips TV 37pfl5604h/12 no standby voltage
      by Bad_IC
      I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
      These are the voltages in some pins of IC fsq510:
      Vcc=18v
      D=320v
      Vstr=154v
      Unfortunately, I couldn't find the schematic
      What else could I check?
      Is it possible to provide standby voltage from an external source to allow the TV to turn on?
      Thank you​...
      11-08-2024, 01:07 PM
    • brock-s
      Asus GL503GE 3.3 standby voltage low
      by brock-s
      An Asus GL503GE laptop arrived that had had a screw dropped on the motherboard while the battery was connected. This resulted in a physical damage to the 3.3v / 5v voltage controller RT6575DGQW (pu28 on schematic, page 40). Additionally, the trace to pin 12 (VIN 19v supply) was burnt.
      Replaced the RT6575DGQW with a new one, repaired the damaged trace. Only getting 0.7V instead of the expected 3.3v standby voltage (3V_S5 on schematic).
      Replaced the AON7408 PQ60 mosfet from a donor board as resistance was low on the gate (I did not write this value down, as I optimistically...
      07-13-2023, 03:43 PM
    • Bloutix
      Ps5 edm-033 bios and southbridge standby voltage
      by Bloutix
      i need your help for understanding if there is an issue around my bios on edm-033 and around southbridge pin P16 and P17.
      I have removed my Southbridge and when I check standby voltage on the bios, I’ve got this value:
      • pin 1: 0,16v
      • Pin 8: 3,3v
      • Pin 7: 3,3v
      I think there is an issue between 3,3v line and cs pin, but I don’t know where.
      then this are the values on SB P17 and P16: 0,93v, But I have 3,3v on L17.
      Thanks for your help....
      10-14-2025, 02:03 PM
