Vizio L42HDTV10A board failure troubleshooting
  • schmok
    • Jul 2015
    Hello!
    I have a Vizio L42HDTV10A that will not turn on when the power button is pressed (on the unit and/or via the remote). The Vizio logo does not turn amber when the television is plugged in.
    At first glance, this seems to indicate an issue with the power supply board, however I am getting 5V at the 5vSB output to the main board. That said, I am getting 0V readings for the 12V and 24V outputs on the power supply board which makes me think there is an issue on the main board (ie. the power supply board is not getting the activation from the main board). There is no visual indication of any damaged components on the power supply board. Suggestions?
    At this point, I am fine with just replacing the entire board that is defective rather than replacing components. Assuming I get the correct replacement board, I am planning on taking a closer look at the failed board and work on it at the component level (just cuz its fun to fix things).
    Re: Vizio L42HDTV10A board failure troubleshooting
    How about pictures of the whole backside of the TV and the boards?
    There are more than one versions of this model:
    http://www.shopjimmy.com/catalogsear...zio+L42HDTV10A
    Did you check the fuses and Voltage regulators on the board?
    It does sound like the main board problem.
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • Awsmessymail
      Vizio E701i-A3 backlight only and now no backlight
      by Awsmessymail
      Hello all,
      I’ve tried to repair TVs in the past with some luck. Toms repair manuals got taken down and now thats a bit harder.
      I picked this TV up hoping for a quick fix. When the TV would power on, only the backlights would come on. The owner told me they heard loud screeching before it shut off. This alone makes me want to think the main board has an issue.
      As I researched, I found the TCON/driver boards were an issue on this unit. I went in troubleshooting the TCON but found good voltages on the TCON. I followed shop jimmys guide to test the transistors and they seem okay....
      02-13-2024, 11:04 PM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
