possible simple problem with LED Projector.
+ More Options
Posts
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    ok guys bought this http://www.ebay.co.uk/itm/1817054607...%3AMEBIDX%3AIT 2 weeks ago and recieved it last wednesday. I had it not 25 minutes when it started failing.
    I turned it to the WiFi source of the projector which just comes up like HDMI 1 etc and it booted up the onboard android system where i connected wifi to my network etc.
    i downloaded showbox to test out streaming quality etc and about 15 minutes into the movie it crashed and screen went green and made a realy loud buzzing noise through the projectors built in speaker system. i thought it was the projector that crashed but could still pull up the menu, sources and volume control etc. i switched to another source then back to wifi and screen was still green and buzzing continued.
    I just switched it off and contacted seller where i have had no response as of yet almost 1 week later. the day in question i switched it off for a few hours and switched back on and turned to Wifi source and was atleast this time given the shiny android logo and it booted up but just after android home screen displayed the screen went black and "No Signal" started roaming about the screen. i have shut down and restarted up several times since last week and keep checking to make sure its still not functioning which it isnt.
    anyone have any ideas before i need to pay out more money to have this sent back.
    projector cost £228 + i had to pay DHL customs charge of £13 when tv was delivered.
  • withalligators
    • Jun 2013
    • 267
    Re: possible simple problem with LED Projector.
    About the fleaBay transaction, don't wait for a response anymore, open up a case against the seller. If you go a certain period without opening a case you're out of luck. Open a case and the seller will be all kinds of friendly and accommodating. You shouldn't have to pay return fees if the item is broken or not as described. Very likely the seller will simply send you a new one or refund you entirely.
    Can't help you troubleshooting technically though.
      I have seen a teardown of one of these projectors before. I hope you didn't actually pay £228 for it, as that is way too much to pay. They will not meet any of the specifications and are usually based on a small VGA resolution LCD projecting through a small LED array. Picture quality and contrast ratio are poor.
      https://www.youtube.com/watch?v=i3B_KKyntQE
      While you can, I would send it back and get a refund.
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        unfortunatly Tom yes i paid the £228 for it then £13 to delivery guy.. and correct a few things didnt add up when i recieved it they have on ad that it is full HD 1080p but how can that be if it is advertised as 1280*800 but the actual resolution is only 800x480... also 4500 lumens as advertised which is alot lower. during the day you can hardly make out that the projector is switched on and i have an old Dell 1100mp projector which is the same brightness and that is only 1100 lumens, now if im correct is LED not supposed to be alot brighter and they say they are using a 200 watt LED bulb.. i will open a dispute and see what happens.
          Right, it might accept a 1080p input but it will scale it down to the 800x480 panel inside. Not even vaguely HD resolution. The LCD panel loses about 3/4 of the light passing through, so they could be saying the projector has a 4500 lm array - less actually delivered. But more likely, it's just an outright lie. It won't last very long either - as the LCD is massively overheated by dumping all this light, it's quite common for burn marks to appear on the image after some time.
          There is no such thing as a cheap, quality projector -- unless it's one you fix, of course! Projectors involve complex, expensive optics combined with extremely high brightness light sources, and the only technology that's half decent at producing an image, DLP & DMD by Texas Instruments, is pretty expensive to manufacture. Even the best projector though will not beat the image brightness or overall contrast of a good plasma TV.
          A 4,500 lumen LED bulb should appear as roughly the same brightness as a 4,500 lumen xenon or HID bulb. Being LED does not make it any brighter, just more efficient (usually.) 200W LED bulb my arse, that's crazy. That's nearly equivalent to a 2kW HID bulb and would be absurdly bright. (Most projectors use 90-150W HID bulbs.)
            Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation P Specification for Upgrade or Repair
            This specification for the Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P51s + ThinkPad Stack Mobile Projector boardview and P51s + ThinkPad Stack Mobile Projector schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
            09-06-2024, 06:11 AM
          • Grut
            JVC LT-39CA120 - Vestel 17MB171 - Android boot loop
            by Grut
            My JVC (Vestel) LED TV is stuck on a Android boot loop when I switch the power on.
            Previously, I was trying to clean the storage memory (by deleting as many files as possible), I may have delete some start-up Android files.....so I screw it.🤡
            When I switch the power on, the initial JVC is shown. I have tried to run Android 9 from a bootable USB on the TV. It starts reading the USB but nothing happens and the JVC logo and Android boot loop keeps the same.
            Can anybody help me please finding the 17MB171 USB firmware to try to upload...
            11-15-2024, 03:12 AM
          • mon2
            Hisense 55Q9G Android reset / factory firmware reload
            by mon2
            Hello. Have a 55" Hisense TV that starts to load the Android OS (no backlight issues) -> reaches the app screen where you can view the assorted icons including Netflix and always crashes at the same point just after this launch. If I quickly press the cursor buttons, the cursor can navigate to the settings menu but will power off just after a few seconds of this activity. Do not believe it is power related since the crash is very accurate in the boot cycle.
            After the OS 'crashes', the power does go off and the from white LED goes dark for about 20 seconds and then ON again....
            01-03-2024, 10:25 AM
          • harp
            simple win network with optimization issue
            by harp
            simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
            06-23-2025, 11:01 AM
          • jchon
            How do modern TVs with Android/WebOS/Roku/etc boot? Debug ports?
            by jchon
            Hi I'm having issues trying to get my Sony A1E to power on.
            Which made me wonder, how involved is Android in the booting of the TV?
            I'm basing this information on what I can glean from the service manual:
            In my Sony A1E for example I see:
            BKA which houses the main processor and along with the input/outputs.
            DKA which possibly does up-conversion, in the block diagram I see VX1 coming in from the BKA and out to the TCON
            TCON timing board which drives the actual panel.
            On the BKA there's a sub-system called the U-COM...
            06-30-2023, 01:58 PM
