Samsung Un55d6000sfxza swapped mainboard worked for 3 weeks. Bad tcon Or faulty part?
  • sammy76
    • Mar 2013
    • 25
    • usa
    Ok, so i got this tv of craigslist. Symptoms were no power at all, no relay clicking, lights flashing, nothing. Isolated it to the mainboard as unplugging the led strip did nothing, however unplugging the main caused it to turn on with the backlights operating. Ordered a new main and it fired right up, only issue was an incorrectly displayed model number. Fixed that in service menu but nticed it said panel self test failed?? Tried repeatedly to self test, said failed every time.
    2 days ago turn tv off and when i try to turn it back on i notice no power led, take it off the wall and remove the main board, fires up to a blank screen again. Notified the seller who told me a bad tcon could kill the main. If it was the tcon would a new main have fixed it temporarily? Or did i just get a defective part?
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung Un55d6000sfxza swapped mainboard worked for 3 weeks. Bad tcon Or faulty p
    So to clarify you bought a mainboard for a TV that wasn't originally for your TV.
    You've then went into service mode and changed the settings.
    I doubt that the tcon has damaged the mainboard, but to seek a refund from a seller who sold you a working board that you have knowingly tampered with is a bit cheeky.
    • sammy76
      • Mar 2013
      • 25
      • usa
      No, i bought a mainboard thats compatible with my model number but was pulled from a 46" d series. There's several different board versions that are interchangeable with each other. I did not simply buy the wrong board and attempt to make it work. The thread i posted on this is here https://www.badcaps.net/forum/showthread.php?t=46736
      The fact that it worked for almost a month after changing the listed panel size (which is a menu option with several choices for this main and not just manually altering values in the service menu) leads me to believe the two are unrelated. The seller believed that perhaps my tcon was bad and not the main. Thats why i was curious if it would have worked after installing a new mainboard, if in fact the tcon was the issue.
      I should also note that when i Recieved the board the package looked like it had been run thru a sorting machine that perhaps squished it as there was a slight, but noticeable bend in the board. I informed the seller of this and was told he did not have a replacement board. He asked me to check it for functionality before i returned it, when it appeared to be working i believed it was fine.
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • mmartell
        General Questions on the Relationship Between Mainboard, TCON and Panel
        by mmartell
        My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
        I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
        And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
        01-06-2024, 01:32 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Dogindelusion
        Sony XR-77A80K 5 Red Blinks Troubleshooting
        by Dogindelusion
        Hi everyone! I am a new member and am new to electronics repair. I have a background in electrical engineering, but little experience in electronics.
        I have a Sony XR-77A80K which will not turn on and has 5 blinking red lights in the stand-by light. I had previously done a forced factory reset, which removed the error code, and the TV regained functionality for a few weeks. I repeated the factory reset and again regained functionality. This happened a few times until I so I had to begin troubleshooting the error.
        Observations:
        1) I noticed I was not getting...
        08-09-2023, 09:44 PM
