Samsung LE37M86BD Picture Fault
  • alancilia
    • Apr 2013
    • 25
    • malta
    Hi
    I have this Samsung that have an intermittent Fault it seems to get worst
    when the tv gets hot
    I managed to find a you tube video exactly with the same fault :
    https://www.youtube.com/watch?v=du7T4y0vPE0
    I have replaced the T-Con Board 2 times from different suppliers with no
    success ( it could be that they are selling faulty t-cons or something don't Know )
    Has anyone got this problem before or can help a bit ?
    Thanks in advance
  • victor_cj
    • May 2015
    • 90
    • Romania
    Re: Samsung LE37M86BD Picture Fault
    Check or replace AS15-HF or RM5101 on this modules if they are suspicious as faulty.
    The art of fighting without fighting
    • Hamie
      • Apr 2014
      • 1383
      That doesn't look like a tcon fault. I'd say panel, or mainboard.
      • alancilia
        • Apr 2013
        • 25
        • malta
        hi
        I exclude AS15-HF T-con was replaced .
        now before i Buy the main board how can I be sure it's not the LCD Panel ?
        also might bee help full to know that when the tv is working ok you can see horizontal line
        only visible on white picture ,
        • Hamie
          • Apr 2014
          • 1383
          It's almost certainly the panel.
          • steviewonder
            • Dec 2013
            • 183
            • england
            Had the identical fault on a LG,it was the panel itself at fault.
            • alancilia
              • Apr 2013
              • 25
              • malta
              Ok, Thanks for your help.
              • alancilia
                • Apr 2013
                • 25
                • malta
                Hi
                Just to confirm you are right that the LCD Panel is the problem , I discoverd that by pressing the upper part of the lcd the problem disappear momentary.
                So Thanks very much .
                • howardc64
                  Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                  by howardc64
                  • Prior owner tried a replacement main board. No difference.
                  • Samsung 2x red blinking standby LED = panel fault
                  • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                  • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                  • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                  07-19-2025, 10:54 PM
                  09-07-2024, 05:50 AM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
