Celcus LED50189FHDCNTD PSU, swapping with another?
  • Dang
    • Aug 2013
    • 440
    I have the above Tv with a power supply issue, I have tried to locate the problem but to no avail, I've crossed referenced it with another very similar PSU and as far as I can tell all components on both supplies measure the same yet one works and one doesn't so I ask this, looking at the PSUs in the photos, would the replacement be OK as a substitute with it's slight differences? as you can see there are four main differences, there's an extra main cap, two extra ceramic caps on the mains input and one extra by the LED output stage, this also has a different LED power stage to the original using what I believe are T0-220 type diodes to the original through hole. The Tv turns on and is stable but I've only tried it for about two minutes, personally I think it's fine, the back light is flicker free with plenty of brightness, Tv turns on pretty much straight away but I'm not entirely sure it will be good with prolonged use.
    Going back to the original problematic PSU, I've taken a photo of an area where the voltage fluctuates by a hundred or so volts back and forth from about 65v with this subtle clicking noise, maybe once a second. As I've said above, I've tested all components here and cross referenced those figures with what I get with the working one, all are pretty much the same so I'm perplexed, I haven't a clue as to what's wrong with it, the model No: Vestel 17PW07-2 141111 there's no standby light, no cold section voltages and main caps do fully charge to around 390v.
  • Dang
    • Aug 2013
    • 440
    Re: Celcus LED50189FHDCNTD PSU, swapping with another?
    Hi again, I guess a lack of response confirms it's OK? any ideas on the fault? I know it's a Vestel POS but to get it working again would be preferable, thanks, Andy.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Well, if you swapped the Power Board and the TV is working now. Just save the non-working board for spares in the event you have aPower Board problem in the future.
      • Dang
        • Aug 2013
        • 440
        All I'm worried about is the power consumption of the 50" LED Tv vs the 39" from which the working PSU is borrowed, if the 50" draws more current it may cause the PSU to go again at some point, personally I do think it's OK but others may have more experience with these sorts of things and so give an educated response. I'm going to have to replace one or the other at some point so to get the faulty one working again would be great or it's £25 from Evil-bay, so if anyone has any ideas please I'm all ears, thanks, Andy.
          Lenovo ThinkPad T16 + Extra 8GB memory Notebook Specification for Upgrade or Repair
          This specification for the Lenovo ThinkPad T16 + Extra 8GB memory Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T16 + Extra 8GB memory boardview and T16 + Extra 8GB memory schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-07-2024, 06:21 AM
        • zwect
          RTX 4060 Gigabyte Aero / FBVDDQ not switching on despite compatible IC swapping
          by zwect
          I got this Gigabyte Aero RTX 4060 where it initially wouldn't get detected, after disassembly i found that U504 (12v to 5v) was corroded at pin 1 together with it's ADJ resistors, i swapped them for close enough ones (it goes to a 1.02k resistor > 340ohm then 0hm > GND), i installed a 1k and 300ohm one and got 5v properly, fans would spin fine but card still wouldn't get detected, i've measured PEX present then found out that FBVDDQ was missing entirely, analyzing further, U15 was shorted at it's VCC pin (7), at the time i didn't have another exact model but got a TPS51211 instead, i checked...
          07-21-2025, 05:53 PM
        • Acnologia
          HP 17-BY BIOS Dump Request ?
          by Acnologia
          Hello to all,
          Laptop with changed cover (back) so i don't know the exact service serial number etc.
          The board has a sticker from HP showing HP 17-BY and some extra details , and i cross-referenced it to the max of my capabilities.
          07/23 M/B SPS L22736-601
          CS 1974
          CMW97B2006R
          CT:PHHNU00WBCJ0AN
          17" KBL-6L
          Can someone give me a clean , bios dump?
          My original i think it's broken.
          Laptop updated firmware/bios and shut down and never came back....
          04-25-2025, 12:13 AM
        • Widget
          Anyone repaired Ionmax ION390? I have extra screws :(
          by Widget
          Re-assembling a Ionmax ION390 air purifier after removing the top LCD control panel, I seem to have 2 extra screws that I, for the life of me, cannot see where they go. I've taken a couple of pictures, buuuuut there's always that one picture you need, but you didn't take :/.
          I know it's a long-shot but has anyone repaired this before would have an idea?...
          04-26-2023, 11:15 PM
