Mitsubishi WD-60638 DLP FIXED
  • matt@bdtinc.com
    • Jun 2015
    • 19
    I recently had the joy of fixing a Mitsubishi WD-60638. The customer stated that her bulb went bad and after installing the new bulb, the TV started smoking and the TV would no longer turn on. She had taken it to a local shop that has been around for years, but after several weeks of getting the run-around about needing to order two fans, a new ballast and a color wheel, she got the TV delivered back EXACTLY like it left only $100 poorer.
    The leads coming from the ballast to the lamp housing had melted the connector. even without being connected to the lamp the inside was so damaged it was arcing and smoking! The lamp housing didn't have any damage The technician said the only way to get a new connector was to to purchase the ballast as it comes with it (seems reasonable). As a temporary test, i simply spliced two female molex connectors , insulated them well from each other, and slid them over the lamps two pins and routed the ballast wires.
    The lamp lit! This confirmed there wasn't a problem with the color wheel at all, as the ballast shouldn't get the turn on signal unless the wheel is up to speed. However a few minutes later the set powered immediately off with no cooldown period. The codes on the front panel flashed "42". Although I could not see this code listed in the service manual, a quick google search said that it is a fan code. By manually spinning the fans by hand, it seemed that the squirrel cage fan the blows on the lamp did not spin as freely as it should even though it WAS spinning. Once again as a temporary fix, i spliced a 12V CPU cooling fan with roughly the same RPMS as the mitsubishi fan into its place (i wanted to make sure the tachometer was going to see the same speed and think all was well. Surprize! set ran for several hours using external cooling with no issues whatsoever!
    I found the lamp connectors without having to buy an entire ballast at Digikey:
    https://www.digikey.com/us/en/ph/Mol...red%20Products
    So now I just need to order and install the replacement fan available a lot of places but also Digikey:
    http://www.digikey.com/product-detai...-00-ND/1633652
    I'm still not sure that her original bulb was bad but I believe she shipped it back to Mitsubishi. I think from reading other threads that when she went to install the new lamp, she did not insert it fully, causing the arcing at the connector and subsequent smoke/melting. The slow fan may have contributed somewhat but I have no way of knowing.
    Total cost of repair under $50. Just goes to show that even good companies can have sub-par or even dishonest technicians!
  • AJ847.63e
    BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
    by AJ847.63e
    Hi All.
    Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
    The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
    09-18-2023, 06:42 PM
  • Divinesense
    Old Acer P7280 Projector - No fans no light
    by Divinesense
    Just for fun I'm trying to figure out what's wrong with my old Acer P7280 projector.
    It shows no errors, lamp or so. Every looks okay. The red led when plugged in and blue led when I turn it on. However, there is no fan spin and no light. After a while the color wheel starts to spin a couple of times, and then stays on. Nothing else happens.
    I have measured all voltages coming out from the PSU, they seem correct, the ballast is getting it's 380V (If I remember correctly) voltage. 12.5v and 5v standby is present and stable on the main board , other voltages probe ok as...
    10-28-2025, 04:43 PM
  • vestaviascott
    Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
    by vestaviascott
    Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
    Here's what happens:
    1) Power on
    2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
    3) Blue status light flashes for appx 4 minutes...
    07-29-2020, 06:08 AM
  • Grouickman
    Hofmann geodyna 6300 Wheel balancer
    by Grouickman
    Hi there,
    First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
    Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
    I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
    I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
    03-31-2025, 05:29 AM
  • mikey5791
    Help on Samsung Syncmaster T220 dead ccfl lamp
    by mikey5791
    This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
    Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
    10-18-2020, 03:17 AM
