Sony KDL-46S2000 main board/B board
  • grafixlad
    • 11
    Hi all-
    Does anyone know if the main board/B board in a KDL-46S2000 is the same as/comparable to the main board in a KDL-40S200?
    (or any of the other similar sets in this series?)
    From what I'm looking at online, they appear to be "visually" identical, but didn't know if any of you with much more knowledge in this area might have an answer.
    Any feedback/insight is much appreciated. Thanks!
    jeremy
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Re: Sony KDL-46S2000 main board/B board
    It is possible..you must compare the numbers on the board to ensure compatibility.
    1-869-852-21 shows up under both model numbers..but there is also a different model used in some of the sets that does not show up under both models.1-869-952-12
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • JDC
      by JDC
      ONN 100012588
      Long answer:
      07-15-2022, 07:39 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
