Toshiba 75023298 (PE0949A, V28A001247B1) Main Board HELP!!!
  • mattstolte
    • Dec 2013
    • 612
    • usa
    I GOT THIS TOSHIBA TV AND NEED A MAIN FOR IT I CANT FIND ONE. OR DOES ANYBODY KNOW HOW TO FIX THIS MAIN. I HAVE 5V STANBY BUT DONT GET THE BL_ON THE POWER LED LIGHT BLINKS THREE TIMES ACCORDING TO SHOP JIMMY THE MAIN IS USED IN MODELS
    Toshiba
    32TL515U
    42TL515U
    47TL515U
    55TL515U
    I HAVE THE 42 MODEL ANY HELP PLEASE
    Re: Toshiba 75023298 (PE0949A, V28A001247B1) Main Board HELP!!!
    PLEASE DO NOT TYPE IN ALL CAPS IT READS LIKE YOU ARE SHOUTING.
    Have you checked all voltage regulators, maybe check if anything is getting abnormally hot, or check service manual to see what error code 3 might mean, if it's specified.
    • mattstolte
      • Dec 2013
      • 612
      • usa
      sorry bout the caps. the only voltages I am getting is the 5v on the psu so that would be a bad main correct?
        If you have no PS ON signal yes. But if you did have a PS ON present then it would be a powerboard fault.
        • gadget
          • Sep 2017
          • 4
          • usa
          Toshiba
          32TL515U
          42TL515U
          47TL515U
          55TL515U
          ther are lots of them on ebay for a cheap price . i bought one for 29 dollars for my 42inch 3d toshiba
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            Yesterday, 08:34 AM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • JDC
            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
            by JDC
            ONN 100012588
            Issue: No Power, Then Rebooting After Main Board Change
            Short answer: replace main board and power board
            Technical answer: replace main board and Q306 & Q307 on power board.
            Long answer:
            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
            07-15-2022, 07:39 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
