Simon brought his Kuro over as he had an issue with a pink tint on bright scenes. It's had this issue since it was fixed but I guess it finally bothered him enough to get it fixed
Initially, I tried setting all panel voltages (via RS232) to the stock settings - 128 all around. Then I tried setting VSUS to code 150. This did not affect the picture. I tried lowering the ABL point, I tried increasing the VOF and VYF -- no change. Very confused, I set voltages again back to factory (always important to adjust from a known baseline)
I then tried adjusting the YSUS/XSUS resonant points YSUS_B XSUS_B. Adjusting these positively made the picture much worse, around 135 (from 128) made the whole panel pink. I then went the other way back from 128 to around 115. This made the picture perfect!
I noticed some cyan discharge errors in purple and pink colours, to fix this I increased V4F and decreased V3F. The delta between V4F and V3F has a significant effect on maldischarge. V3F also lowers the black level, but if V3F is too low other picture faults will occur.
Finally, I tested it on all types of content and the panel was declared to be fixed
