Main Board symptoms
  • tech2014
    • Aug 2014
    • 807
    Main Board symptoms
    I have a plasma tv that when the power is applied there is no clicking sound fro the p/s. The ps_on voltage stays at 3.3v and vs_on stays at 0v. Pressing the power button on the tv or remote and the ps_on stays at 3.3v rather then go to 0v. I tested all of the boards and they are all good. Would this be a bad main board?
  • Ltank
    • Jun 2013
    • 776
    Re: Main Board symptoms
    Can we get the Make and Model of the set and maybe a pic of the Power supply connector and labeling? And a pic ofthe main board. It would be helpful
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      by JDC
      ONN 100012588
      Long answer:
      07-15-2022, 07:39 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
