Vestel firmware
  • steviewonder
    • Dec 2013
    • 183
    • england
    Vestel firmware
    Hello once more,
    Having the usual hard time attempting to download firmware updates for vestel rubbish...This time for a Toshiba 22D1333B.
    I seem to notice that vestel make this virtually impossible,and this tv has the usual red/green flashing lamp.
    Do they purposely go out of their way to prevent engineers from downloading software for their own cock-ups?.the flash corruption levels are beyond a joke for their products,and was mortified to find out even Panasonic uses their rubbish now.
    we have Sharp,Toshiba,jvc,and other big name brands which is essentially supermarket cack.
    Wonder what else is around the corner...
    • 31084
    Re: Vestel firmware
    what make flash chip do vestel use?
      Re: Vestel firmware
      I've seen Spansion used on a lot, Winbond for smaller stuff.
      The problem is the flash memory wears out due to high temperatures and small process size. MLC NAND flash has a 3,000 cycle lifespan, if the TV is writing to the NAND a lot, it will fail.
      • thoma
        • Sep 2012
        • 268
        Re: Vestel firmware
        What does this mean to change the mainboard?!
        mfg thoma
          • 31084
          Re: Vestel firmware
          i wonder if you can get compatable FRAM chips.
          i know you can by 24' series compatable FRAM.
          • steviewonder
            • Dec 2013
            • 183
            • england
            Re: Vestel firmware
            Yes Tom, but we are talking about 12 month old vestels,it's unlikely any vestel would operate 3000 cycles of off/on etc...even samsungs and lg sets used daily from 2006/2007 do not seem to have the vestel issues.
            Just very poor design,i put it down to,and a tight lipped "we are keeping the 30 second flash update fix to ourselves" approach they seem to have...
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Re: Vestel firmware
              I hate them nightmares to repair and normally the customer wont pay alot if the tv isn't that old.
                Re: Vestel firmware
                Well when they pick it out of the Argos catalogue for £70 why would they!
                Would be interesting to attach a serial port emulator to the appropriate SCART pins - apparently there's a debug port on two pins.
                • Bazilwrc164
                  Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                  by Bazilwrc164
                  I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                  The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                  I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                  If anyone can provide:
                  • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                  • Or a compatible EEPROM dump
                  07-23-2025, 12:15 PM
                • massimomax
                  Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                  by massimomax
                  Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                  spero che qualcuno può averlo per riprogrammare eprom. grazie
                  Post in English !!!
                  I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                  02-28-2025, 07:27 AM
                • anlu
                  Vestel Firmware - Toshiba 32W133DN
                  by anlu
                  Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                  Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                  02-04-2023, 12:59 AM
                • piernov
                  Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
                  by piernov
                  Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
                  I suspect corrupt firmware but I haven't been able to find anything for this TV.
                  TV model: Finlux 65-FUC-8060
                  Mainboard: Vestel 17MB130S 23473048
                  Panel: VES650QNTS-2D-U11
                  At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
                  06-01-2024, 12:57 PM
                • TheUser
                  Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                  by TheUser
                  Hello to everyone ,
                  This is my first post here, and i would like to share with you a small story in case you can help me.
                  Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                  All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                  I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                  02-10-2024, 02:07 PM
