Panasonic TC-P50VT20
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Re: Panasonic TC-P50VT20
    A6 disconnected readings of pins on A board
    pin 1 = 1.1Mohm, pin 2 = 4.7Mohm, pin 3 = .6 ohm, pin 4 = .6 ohm, pin 5 = .6 ohm, pin 6 = 12.8Kohm, pin 7 = 12.8 Kohm, pin 8 = 12.7Kohm, pin 9 = .6ohm, pin 10 = .6 ohm
    with sc and ss disconnected, faults on 7 blink SOS.
    SC and SS connected sc=2.2 volts, ss=2.2 volts
    only ss connected sc=208volts ss=169 volts
    only sc connected sc = 2.2 volts ss = 2.2 volts
    no sc or ss connected sc = 208 volts ss = 208 volts
    With both connected and A6 connected again back to 10 blinks.
    • tw2005
      • Oct 2011
      • 6458
      something is wrong, can't be possible to have 208 on sc side and 169 on SS side, it's the same volatage produced for both in one cct so both have to equal the same.
      can you locate TP82 on the Sc, near Sc20 connector and check resistance - gnd pad on sc board. that's the 15V in for that Sc.
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        My bad..We have 208 on sc side and 198 on ss side with only ss connected. TP82 reads 2.13Kohms to ground pad on board.
          Are you sure you have different voltages? The same PSU output should be used for both. They should read roughly the same.
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            If I disconnect ss board AND sc board, they will be the same. with only ss connected, ss reads 198 and sc reads 208.
            • ljintexas
              LJinTexas
              • Jan 2015
              • 669
              Once 15 sec has expired and shutdown occurs..reading on ss goes to 204 then starts bleeding down.
              • tw2005
                • Oct 2011
                • 6458
                well, I don't know if I'm barking up the wrong tree but it's not making much sense,.
                Losing vsus with the Sc says to me bad SC, also no 10 blink but 7, if the F15v and subs were being shorted I'd expect vsus not to get up and still 10 blink.
                I'm winging this next suggestion.
                Disconnect
                Sc2, Sc20,ss11, p35, at the d board, disconnect any ribbon that feeds any c board upper or lower, leave connected to the A.
                power it up and see if it blinks or stays on. don't reconnect anything. I'll see if I can dig up the aussie A-board and measure those A6 points, not sure if they match up or not with my version.
                • tw2005
                  • Oct 2011
                  • 6458
                  oh, and only run for 30sec or less or the TV will shutdown with an error, maybe 4 blink
                  • ljintexas
                    LJinTexas
                    • Jan 2015
                    • 669
                    Will try it this afternoon. Thanks! If we suspect sc, should we test su and sd to make sure they did not whack sc?
                    • ljintexas
                      LJinTexas
                      • Jan 2015
                      • 669
                      I have access to an sc board within a couple days.
                      • tw2005
                        • Oct 2011
                        • 6458
                        good idea to check buffers, yes.
                        still not happy to commit to what's going on yet. looking for that smoking gun
                        • ljintexas
                          LJinTexas
                          • Jan 2015
                          • 669
                          Good news is we have time..what is good test procedure for su and sd?
                          I appreciate your time and effort! If you ever need anything from this side of the world, just let me know.
                          • tw2005
                            • Oct 2011
                            • 6458
                            what I need is some clear cut evidence. LOL
                            unfortunately I'm trying to upgrade my pc so I can't access my files. not going well.
                            the g20,g25 guide has a good resistance check, I'm not good enough to remember the exact pins and readings , have posted this a few times now.
                            • tw2005
                              • Oct 2011
                              • 6458
                              https://www.badcaps.net/forum/attach...5&d=1430296122
                              sd/su resistance tests are in that, I think VFO, Vscn, vf5v, could have those muddled but you'll see when you read it
                              • ljintexas
                                LJinTexas
                                • Jan 2015
                                • 669
                                I grabbed the G20/G25 tech manual..good info in there.. I will test the buffers.
                                • ljintexas
                                  LJinTexas
                                  • Jan 2015
                                  • 669
                                  Disconnect
                                  LED Stays on solid...no blinky
                                  Everything still disconnected. AFO
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Originally posted by ljintexas
                                    Disconnect
                                    ok, well my washing machine just died, looks like i'll be busy fixing my problems but that suggests it was on, I would have then check vsus again to confirm on and voltages feeding the a board especially 15v.
                                    Seems like SC but we just have not found a part shorted, feel free to keep looking I'd check all the IGBT transistors on the heatsinks.
                                    If it is on, that means 10 blink is not P, A or D but 1 of the other boards.
                                    That's about the best i can do without spending ages looking at the diagrams, i guess potential short or c boards may cause it but the loss of vsus with SC connected and restored with it removed strongly suggests that is the most likely item.
                                    Good luck, I'm heading out tonight and I'm a little stressed hope you understand,
                                    • ljintexas
                                      LJinTexas
                                      • Jan 2015
                                      • 669
                                      Thanks for you r help. Just fixed a whirlpool Vertical Modular Washer..it needed a shift actuator and a mixing valve..I am going to remove and analyze SC..My money is on it.
                                      • ljintexas
                                        LJinTexas
                                        • Jan 2015
                                        • 669
                                        If I can assist with washer..let em know fixed a ton of them through the years.
                                        • ljintexas
                                          LJinTexas
                                          • Jan 2015
                                          • 669
                                          SU and SD read OL on all resistance tests. Wierd.
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                          • Rensiee
                                            Panasonic TH-50PX8EA Black screen, only relay clicks
                                            by Rensiee
                                            I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
                                            I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
                                            When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
                                            I have measured the voltage in the VSUS line, which...
                                            06-18-2024, 12:58 PM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • DodgyTech
                                            60" LG 60PB690V relay clicking issue
                                            by DodgyTech
                                            I require some help with my TV. The TV standby light blicks on and off with a clicking sound (relay?) from the back. After I opened up the TV, I set about troubleshooting by unplugging the boards to try and isolate the problem. My troubleshooting suggests that the logic board is causing the issue, but it could entirely be the YSUS board which is only activated once the logic board is connected.
                                            I have recorded a video which I thought would be an easier way to explain the problem and show the boards at the same time.
                                            I would like to try and identify...
                                            07-07-2023, 10:30 AM
