technika 17pw 26-3 power issue
  • arc2002
    • May 2015
    • 17
    • uk
    Re: technika 17pw 26-3 power issue
    my stupid bad fellas , false alarm, having been messing around with the set so much with its back off, i forgot that the buttons which are flush touchpad type were on the other side, so all i was actually doing was touching up the plastic frame!!
    once i realized what i was doing wrong and actually pressed the on/off the set fired up as it should.....
    thats it i am officially declaring myself senile..
    ian
    • newtothis
      • Mar 2013
      • 1556
      • england
      LOL
      Glad its working
      • arc2002
        • May 2015
        • 17
        • uk
        cheers fella,
        and thanks for your all of your input
        unorientated
        ian
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
          🛠 Original Issue
          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • ugamazing
          Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
          by ugamazing
          I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
          We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
          12-17-2024, 07:05 PM
        • Simone Vergani
          Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
          by Simone Vergani
          I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
          To assist with troubleshooting, I'm attaching two power circuit schematics:
          • Power
          03-05-2025, 02:25 PM
        • wizard13
          Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
          by wizard13
          I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
          I have checked the forum and the available documentation but could not find a solution specific to my issue.
          • Brand & Model: Dynabook Satellite Pro C50D-B-100
          • Part Number (P/N): PYU13E-00C00PFR
          • Serial Number (S/N): 22028896H
          • System Configuration (SC): A1PYU13E1127
          • Motherboard Model: IP3_ACN16_MB_V21_20211222A
          • Power Input: DC 19V –
          02-28-2025, 02:43 AM
        • Titus6
          LG OLE65C1 Stand-By issue
          by Titus6
          I bought an OLED65C1 refurbished TV back in 2022 from a shop. The TV is awesome, this is my first OLED and I really love it.
          However I have an issue with the TV since the end of last year. I noticed when my TV is in Stand-By, sometimes the LED goes off then comes back on. When do so it seem periodical. It only goes away for 1-2 seconds, than comes back on. The TV NEVER turnes off, while it's on, so it's not overheating issue or electrical power issue.
          I bought a service remote (MKJ39170828) and checked the menu 3. Power On/Off Status. I took...
          01-31-2025, 04:01 PM
