LG 42PJ350-UB won't power on all the way?
  • pilotguy251
    • May 2015
    • 24
    I am troubleshooting my LG 42PJ350-UB, and it will not power on. I purchased a new Power supply for it about a month ago, and then a new main board earlier this week. Upon putting in the new parts, I get something I wasn't before, but it still won't power on fully. The relays click, the screen lights up for about a second, then the relays click again, along with a green LED on the logic board, and the set goes back off. And as long as the TV is plugged in, the cycle continues. About five or so seconds between off and partway on. What's going on here and is there any way that I might be able to fix it? I'm thinking about just giving up and parting it out if I can't get it working again.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 42PJ350-UB won't power on all the way?
    Could it be the backlights then??
    • pilotguy251
      • May 2015
      • 24
      Well, they do light up, and before I got the new mainboard, I could power up the set and the backlight would stay on until I unplugged it.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8326
        So if you force the PSU on with the main board disconnected, the backlights come on and all the voltage rails come up?
        • pilotguy251
          • May 2015
          • 24
          That's what it did at first, now it just clicks right back off after a few seconds with the new board in, even if it's disconnected.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8326
            Well... I guess you either swap or fix that PSU first.
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              42PJ350 is a PLASMA TV set,
              http://www.lg.com/uk/tvs/lg-42PJ350-plasma-tv --Therefore, has NO Backlights.....
              Sounds to me that the Control-Board is Detecting fault on either Y-SUS or Z-SUS and shutting down the set....
              Start by checking all the voltages while the set is running--for the short time it does...
              Voltages such as Vs, Va, VSC, -Vy, and VZ-Bias are important and if way out can cause the Control-Board to detect fault and shut down.
              TELEFIX
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8326
                pictures folks... pictures!
                • pilotguy251
                  • May 2015
                  • 24
                  Yeah, upon testing the voltages for the short time that it comes up, they go up to about 180 on the leads before it goes down.
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    Please provide pictures of your boards and overall layout of them all connected please
                    • pilotguy251
                      • May 2015
                      • 24
                      Hope this helps
                      • newtothis
                        • Mar 2013
                        • 1556
                        • england
                        Ok can you test the VS, VA etc as stated in post #7 and list them for us
                        • pilotguy251
                          • May 2015
                          • 24
                          VS peaking at 186v for the short time that it comes up and the VC is at around 60v. Nothing on the grounds, NC 180v and M5 V 5v
                          • newtothis
                            • Mar 2013
                            • 1556
                            • england
                            VSC, -Vy and VZ-Bias?
                            • pilotguy251
                              • May 2015
                              • 24
                              Are those on the power supply board? Don't see any of them labeled that just yet.
                              • newtothis
                                • Mar 2013
                                • 1556
                                • england
                                Couple highlighted here
                                Have to hunt around for -Vy
                                • pilotguy251
                                  • May 2015
                                  • 24
                                  110v through the VZ, 293v through the VSC, and still hunting for the -Vy
                                  • Alastair E
                                    Chief Womble
                                    • Mar 2013
                                    • 1963
                                    • U.K.
                                    Picture of the Panel Label too please--Has the vital Voltage Info on it....
                                    TELEFIX
                                    • newtothis
                                      • Mar 2013
                                      • 1556
                                      • england
                                      Voltages
                                      Va : 60v
                                      Vs : 205v
                                      -Vy : -195v
                                      VSC : 145v
                                      Zbias : 115v
                                      I think that is the way LG stickers are formatted anyway
                                      • pilotguy251
                                        • May 2015
                                        • 24
                                        Wow, that's interesting. Didn't see that at first. Well it looks as if they want to reach those, some do, but it clicks back off before the voltages stabilize.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
