Seiki 50 inch has no back light
Re: Seiki 50 inch has no back light
There also appeared to be one hell of a lot of leds, 20 plus rows and maybe 50/60 leds per row. The leds didn't have any diffusers on them so I suspect that with that number of leds the drive current was probably set low and so as not produce any bright spots when viewing. Just my thoughts,Willing to help but I'm no expert.Comment
yes that makes sence it did not look a bad picture as the leds didnt have diffusers lens fitted over them.
Edit was typing same time as you same thoughts too regaring the ammount of leds used but if its a good picture and the set lasts a while i suppose thats all what matters if for own use and not re sale.Last edited by vinceroger69; 02-16-2017, 07:35 AM.Comment
What I am trying to accomplish is being able to light the Led Back-lights when there exist a bad strip lighting the remaining strips without opening the screen and risking cracking the screen
In other words some way of using resistors and/or diodes in place of the defective Led strip or, to complete the circuit which will allow the remaining strips to light or,
To override or disable/change the protect circuit so the back-lights will light
Any help would be greatly appreciatedThis Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
Help keep these from the landfillsComment
It's a pity the manufactures do not enclose the panel in the same frame as the diffusers so the whole assembly could be lifted off leaving just the leds exposed which would make servicing so much easier.Willing to help but I'm no expert.Comment
Since there are so many Leds I have not noticed a great deal of difference mostly due to the diffusers over the Leds and the white Diffuser panel below the screen tends to spread the light somewhat normal
There is sometimes a barely noticable dim area but, otherwise usableThis Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
That would be way too easy
I think they simply do not want the TVs serviced anymore and simply disposed of
They could care less about our Landfills. Have anyone ever seen theirs? Because, there is not much which can be done with disposed TVs at all without a great deal of effort which always results in backwards investments
In fact, some manufacturers actually use adhesive sealant around the screen frame which requires force to remove and most times results in cracking the screen. Also, the Ribbons are only glued onto the address buffer and many times become unglued which results in lines and bars on the screenThis Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
I will try to understand BudM's suggestion IF I can try understanding how to find the test points
See:
All the wires from the LED strips come back to the LED driver section of the power supply/driver board, the problem is, you need to know if those wires from the LED strips are terminated as one series connection or each strip may be driven by individual LED driver. You have to look at the LED driver section to find out how the Cathode return wire of each LED strip is connected to.
If you use one of those LED tester such as the one sold by shojimmy, the LED strip that has shorted LED will still light up, so it is important to read the Vf Voltage as shown on the tester and compare it to the other strip (with same LED setup). The Vf will tell you if one or more of the LEDs have shorted out or not. You can use 2W 3.3V connected in reverse bias in place of a LED, I use 5 1N4007 (I have lots of them) is series and connected in forward bias in place of the bad LED (the diode will get quite warm).
https://en.wikipedia.org/wiki/LED-backlit_LCD
"direction as to how exactly Leds function"
https://en.wikipedia.org/wiki/Light-emitting_diode
Want to learn?
https://www.maximintegrated.com/en/a...ex.mvp/id/4384
Well I think you need to use simple logic, the tool will tell you you have open circuit, just thing about it, if you use Ohm meter to check the resistance of 1 Ohms resistor but it shows open circuit, does that make Ohm meter useless?Never stop learning
You have to have knowledge and ability and understanding how to figure out how the LED strips are terminated and how to tell how many LED driver circuits are being used on the LED driver board. That is the starting point. You know how to read circuit diagram, right/ Go to Tom66 web site and down load some of the SAMSUNG service manual and BN44- XXXXX diagram for the power supply and study them.I will try to understand BudM's suggestion IF I can try understanding how to find the test points
See:
Want to learn?
What is your level of electronics knowledge?
I ask becuause you ask the question in post 38:
"BudM,
So, the device that ShopJimmy sells will not work if an Led is open and, only work if it is shorted?
If so, then the device is not of much use since many times Leds go open correct?"
If you really think about it and use simple logic then you will know why the tool is good, so lets say that the LED string does not light up, then ask yourself, is it because the LED string had open LED or the LED power supply is not working?
If you think the tool is not much use, then think about your meters you use to take measurement, that will make them useless too. The tools tell you what the DUT condition is.Last edited by budm; 02-16-2017, 10:11 AM.Never stop learning
"BudM,
That is correct. I understand
I was just under the impression that although the entire string is serial that the Strip was not
Also, I have determined that if I reduce the voltage considering the missing strip or, part of strip that I can make it work
In other words, the entire Strip needs 120 volts to light, which contains 40 Leds and 10 were missing I could then use 90 Volts which should light the backlights if the defective string were jumpered or,
Would it make more sense to use a string of diodes in place and keep the voltage the same? Although the Diodes may generate some heat.
What are your thoughts BudM ?
Thank you in advanceThis Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
Reducing the output Voltage of the existing Boost converter power supply can be done if the circuit used in your board matched the application notes of the LED driver IC.
30 LEDs you will need 90V for the total Vf of the LED STRING + V drops (typ. 15~30V) on the PWM Controlled POWER MOSFET and I -sense resistor for maintaining constant current through the LEDs, the key is to maintain constant current through the LED (Vf of LED also change with temperature and the amount of forward bias current, see LED spec sheet for more details).
Bottom line is you can modify the circuit if you have the diagram and the data sheet of the ICs.Never stop learning
I have to say
BudM you are the best!!This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... -
by PNI E.hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
by koby058Hi people!!
The owner said it showed bad picture once in a while (attached)
I see that there is back light but no picture.
I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
Also attached schematic and BDV
LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590... -
This specification for the HP ZBook Firefly 16 inch G10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 inch G10 boardview and 16 inch G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 07:20 AM
This specification for the HP ZBook Firefly 16 inch G10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 inch G10 boardview and 16 inch G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 07:19 AM
- Loading...
