sharp aquos lc-60le636e dark picture
  • wreksta
    • Aug 2013
    • 508
    • england
    Hi all i have the chance to buy this tv cheap seller says it has a contrast
    Problem aa the image is dark like its inverted
    Amy ideas will upload pics shortly
    Just after a few members thoughts before i waist money
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: sharp aquos lc-60le636e dark picture
    Just from saying the word inverted makes me think .oO(Gamma IC) though usually see them "lighter" washed out
      Gonna put a bet on a bad panel. Or bad LEDs.
      • newtothis
        • Mar 2013
        • 1556
        • england
        More than likely with the amount we are seeing
        • wreksta
          • Aug 2013
          • 508
          • england
          Photos uploaded
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Photos uploaded
            Err--Where....?
            TELEFIX
            • newtothis
              • Mar 2013
              • 1556
              • england
              Yes I think you have forgotten to attach them
              • wreksta
                • Aug 2013
                • 508
                • england
                Sorry all they wouldnt upload last night
                Ive been into service mode and the tv is bright and no problems in there
                Tried a reset but it still remains the same
                Any ideas now
                Will try get pictures up today
                • wreksta
                  • Aug 2013
                  • 508
                  • england
                  • wreksta
                    • Aug 2013
                    • 508
                    • england
                      I would say bad panel. Hard to be certain but looks like it.
                      • wreksta
                        • Aug 2013
                        • 508
                        • england
                        Hi tom i hope its not mate
                        Service menu gives a clear bright screen after a reset i get a sucess screen nice bright green background
                        To me it looks like a mainboard or tcon problem
                        Not all menu text is visable in dtv mode some is dark some is bright
                        Any thoughts mate
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          if this set was mine and a tcon was cheap i would probably try one to rule it out you can always re sell it if it does not solve the issue.
                            It just looks like colours are distorted - not dim or lack of brightness.
                            It could be panel or t-con.
                            Maybe main IF the settings are wrong (cont/bright/etc) -- but I really doubt it.
                            Test pattersn can be found in service menu, so try them.
                            Having seen this on lots of other sets tho it's usually panel, only t-con on the few with AS15 gamma ICs
                            • wreksta
                              • Aug 2013
                              • 508
                              • england
                              Thats just it the test patterns dont show if i press right tp choose test pattern it will flash up and off really quick cant acess any other patterns and the whole digital tv picture is dark like inverted colours
                              Also could it be water damage corrosion on the main panel ic boards ?
                              • wreksta
                                • Aug 2013
                                • 508
                                • england
                                Any ideas on what i have said
                                • wreksta
                                  • Aug 2013
                                  • 508
                                  • england
                                  update
                                  ive stripped down the main screen to driver boards
                                  i found liuid damage and a burned flex ribbon from tcon
                                  so i think the tcon is short hence gamma contrast problem
                                  im not sure though any thoughts
                                  as i get the full characters and colours on the service menu does this mean that if i replace the tcon the screen will actually function perfectly
                                    Liquid damage = Bad panel
                                    Sorry, but it's dead. Liquid damage is basically terminal in 99.5% of LCD panel cases.
                                    Sometimes, if the damage is VERY light, like only a few contacts, it can be repaired. But that is the exception rather than the rule.
                                    Strip it, trash the panel.
                                    This is why I got out of the biz.... too much shit like this. Plasmas didn't used to die like this from a drop of water. Hah.
                                    • newtothis
                                      • Mar 2013
                                      • 1556
                                      • england
                                      I don't repair TV's at all anymore! As Tom stated to many failed panels!
                                      • Danstona
                                        LG 65UK6090PUA - picture dark
                                        by Danstona
                                        Was watching this set, and suddenly it went dark. Picture is still visible, just very dark. Tried checking all settings, adjusting brightness to 100% no change. Reset through menus, no change.
                                        bought used boards from ebay (power and input boards) replaced with same results, changing brightness does seem to have a slight affect.. but not to normal visibility of picture.
                                        I'm handy, fixed TVs before.. I can't see any issues with boards... hoping someone can point me in the right direction to properly diagnose. I don't believe the LEDs are caput, since the picture is on and equal...
                                        03-10-2024, 12:41 PM
                                      • Bazfletch3
                                        Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                        by Bazfletch3
                                        Hi all
                                        While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                        I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                        From there I envisaged that the backlighting wasn't working, however...
                                        01-08-2024, 10:18 PM
                                      • sefoster
                                        Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                        by sefoster
                                        I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                        11-20-2022, 09:29 AM
                                      • Javiercity
                                        [B][/B]Sharp 80" lc-80le661u dark spots/shadows
                                        by Javiercity
                                        Hello there i have a Sharp 80" LDC that has some dark spots in the middle of the screen, since its a 80 inch need another person so hang it on the wall or move it around, so i hope the collective wisdom can help me to determine what is wrong, I've been doing some research online and there is next to nothing about this TV, i tend to believe that the spots are due the back films/diffuser sheets, that are bit dirty, or perhaps one or two LEDs being burned, but what throws me off is that the dark spots are more noticeable when the image is bit dark like night scenes, and also noticeable when...
                                        06-13-2023, 12:02 PM
                                      • scubacamper
                                        Sharp Aquos LC-70C6400U Half Screen Dark
                                        by scubacamper
                                        I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                        Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                        when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                        05-03-2025, 12:19 PM
