Plasma Tv 42" Hot point No picture no sound
  • ryann2k1
    • Apr 2015
    • 18
    I have a 42" plasma tv brand Hotpoint (it seems the boards are samsung made). When plugging the power source, tv turns on with green light turns on, but no picture and sound. A few second later, it indicator turns to red(stand by mode). After turning on with remote, tv indicator turn to green but still no picture and sound at all. There is one green light on the logic board (i think) which keeps blinking (see attachment). I have tried to unplug the X-board and Y-board( one at a time and all simultaneously) but the problem remains. I have measured Va, Ve, Vset, Vs, all are in normal rating voltage as shown in the specification attached on the back of the panel. Only Vscan which is supposed to be -182v, and the measure one is only -50v. i think this it the problem but i don't know how to further diagnose as i don't have the schematic diagram. Any help would be great. Thanks
  • Hamie
    • Apr 2014
    • 1383
    Re: Plasma Tv 42" Hot point No picture no sound
    Unplug the buffers from the y-sus and check the vsc voltages again.
    • ryann2k1
      • Apr 2015
      • 18
      I have done that, I unplug y-sus and measured, vsc measured at 0v (no voltage), Va,Ve and others are in normal range. I forgot to mention that I have replaced one capacitor at power supply unit, 47uF/50v. I thought that was the problem as the capacitor looks already bulging, but I was wrong, the problem still remains..
      • Hamie
        • Apr 2014
        • 1383
        The vsc voltage might only appear for a few seconds then drop to 0.
        You'll need to quickly measure it as soon as the TV is plugged in.
        • ryann2k1
          • Apr 2015
          • 18
          Thanks I will do that this weekend.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Unlike later sets this one has the -Vy, VSC, VSCAN,, VE etc generated on the PSU board, along with the Va and Vs supplies.
            Some of these supplies are derived from the Vs supply but on the PSU, so any issues with the Vs supply, the PFC etc will give none of the other rails....
            A common fault (It appears) is the PFC and Vs Controller chip can fail--which apparently is rarer than hens-teeth--uses same chip for both jobs--Bit weird.....
            Unless its just for experience--I wouldn't waste any time on this 480i EDTV set, that has no HDMI or DTV....
            --I'm sure it will be great on the spin-cycle though! (Hotpoint make washers here in UK, never any TV's etc....)
            TELEFIX
            • tw2005
              • Oct 2011
              • 6458
              Off topic , but Hotpoint for my memory in the 70's produced pretty good frypans, grillers etc. been gone for a very long time as a brand so probably someone purchased the rights to use it as a rebadge. all speculation of course but there's plenty of badges wacked on chinese TVs, thorn, PYE, AWA, are some others that come to mind. Sanyo was a rebadge for TVs too.
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                I Think Hotpoint was bought by someone like Beko I know Kenwood was amongst others...
                Most TV sets here (Inc Panasonic) are going rebadged VESTEL Vomit, JVC, Sanyo, Alba, Technika, Bush, Baird, Xenius etc --All Vestel Crap!
                Only four or five 'main' makers now--Vestel, Sony, LG, Samsung, Philips--rest will be rebadged or cheap Chinese rubbish with whatever name--or in some cases, NO name on at all--and NO clue who made 'em!
                TELEFIX
                • ryann2k1
                  • Apr 2015
                  • 18
                  the voltage for Vscan is 0-no voltage ( y sus is unplugged). My question is that does the Vscan voltage only appears once in closed loop, unlike Ve, Va, and others?
                  • ryann2k1
                    • Apr 2015
                    • 18
                    the voltage for Vscan is measured from -50 (supposed to be lower than -100v) than gradually decreased to 0 v( y sus is unplugged). My other question is that does the Vscan voltage only appears once in closed loop, unlike Ve, Va, and others?
                    • ryann2k1
                      • Apr 2015
                      • 18
                      anyone can help?
                      • Alastair E
                        Chief Womble
                        • Mar 2013
                        • 1963
                        • U.K.
                        VScan is derived from either Vs or Va on that chassis--cant remember which--But Isnt closed loop as I recall....
                        IF however--There's a fault on Y, then this could be picked up by the control-system/Fault det, that then shuts down the PSU, but not as in closed-loop regulation etc--Unplugging PSU may actually Cause the observed results on an otherwise normal set...
                        --This tends to shut most of the PSU down though....
                        Is Va and Vs present and correct while on?--IF these are wrong/not present then Vscan wont be right anyway, as it is derived from one or the other ...
                        TELEFIX
                        • ryann2k1
                          • Apr 2015
                          • 18
                          Thank you for responding. Vs and Va are in normal range. I am still wondering, if vscan is not close loop...the measured voltage is supposed to be the same, when unplugging the Y sustain and when plugged. When i plug, Vscan around less than -50v but when i unplugged, Vscan = 0v.
                          • ryann2k1
                            • Apr 2015
                            • 18
                            is there any way to get an example of circuit diagram for the "similar" power supply board and Y sustain board?
                            • ryann2k1
                              • Apr 2015
                              • 18
                              Please any one can respond?
                              • KYBOSH
                                Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                by KYBOSH
                                Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                No picture but you hear the TV static (white noise) playing loud and clear.
                                The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                But it seems they didn't get too far and just left it.
                                When I first took a look I was amazed at how pristine the inside looked.
                                Its as if the TV had been in a time capsule.
                                Caps looked like they were just pulled off the self.
                                Copper coils had no sign of corrosion on...
                                02-01-2023, 11:10 PM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
                              • Mgiffune
                                by Mgiffune
                                06-09-2024, 10:28 AM
                              • Ierwin
                                by Ierwin
                                05-13-2025, 03:31 PM
                              • jchang
                                Samsung UN70NU6900F no picture and no sound
                                by jchang
                                Hi all
                                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                Symptom:
                                No picture no sound.
                                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                No sound at all.
                                What I tried:
                                1. I tried unplugging the left or right ribbon...
                                01-09-2023, 06:28 PM
